September 22, 2026, 23:00:20 pm
| | |-+  IDA jetting from scratch help needed
Author Topic: IDA jetting from scratch help needed  (Read 6010 times)
« on: August 29, 2017, 07:53:21 am »
I have sat with this engine in the garage for a while now.  Family, work, house, and an MA all got in the way.
2332cc
42 x 37 CB wedgeports
56cc chambers
raptor cam (don't know lift)
I need to do a cam burn and get it up and running so want a conservative jetting arrangement that will fire up and not lean out.
I have 37 and 40mm venturis.
As far as I can tell they have 135 F7 120 in already.  With idles saying 70F10.
Thanks in advance, this is the last piece of the jigsaw.
« Last Edit: August 29, 2017, 09:30:09 am by Lids » Logged
PPRMicke
« Reply #1 on: August 29, 2017, 10:14:01 am »
Cr ?
Raptor nr ?
« Reply #2 on: August 29, 2017, 14:54:29 pm »
To do cam burn its only going to be on idle circuit so you only really need to worry about that, 70s will be fine and use either vents, if you want a ball park mains then 170s with 200 airs
« Reply #3 on: August 29, 2017, 16:34:53 pm »
thank you
« Reply #4 on: August 29, 2017, 16:35:21 pm »
Cr ?
Raptor nr ?
CR 10:1 , don't remember raptor nr
PPRMicke
« Reply #5 on: August 29, 2017, 18:38:57 pm »
65-70 F10  ( jet holder 120)
160-170 F7 180
Wide band lambda ?    13,6 -13,7 ARF ( lambda  0.86-0.88 )
/// Micke
