September 22, 2026, 23:57:10 pm
| | |-+  What head and crank trigger sensors are you using with DTA Ecu
Author Topic: What head and crank trigger sensors are you using with DTA Ecu  (Read 9123 times)
Rocket Ron
It's old school for a reason
« on: August 30, 2017, 06:36:30 am »
Hi guys
Was wondering who's crank and head temp sensors you are using with your DTA ECU. Looking for recommendations for something that will work and is reasonably priced.
Thank you in advance for your recommendations
Regards Ron
13.12 @ 101.84
Grooving out on life
Erlend / bug66
Global Moderator
SCC Event
« Reply #1 on: August 30, 2017, 07:32:26 am »
VW Speed shop crank trigger and a generic 6mm bolt style temp probe fitted to the #3 cylinder tin bolt. Works good
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
« Reply #2 on: August 30, 2017, 16:12:23 pm »
Ford Zetec crank sensor[and coil] and generic lucas temp sensor[in oil]
Tufty65
« Reply #3 on: August 30, 2017, 20:31:47 pm »
Hope you don't mind jumping in here Ron but it's crank trigger related,
Just trying to understand the ignition side of things a little better and I'm going either DTA or OMEX and presently havens ignition set up consisting of  MSD 6al box with boost retard box and dizzy that came off my old motor which only ran fuel on the ecu and not spark.
Am I right in thinking I need to replace all of the MSD stuff with a crank trigger/coil pack and cam sync system so the DTA/OMEX can control spark too?
Something like these together ?
http://www.cbperformance.com/product-p/7073.htm
http://www.cbperformance.com/product-p/2092.htm
Or is there generic stuff I can get that'll do the same thing?
Richie is this anything you sell ?
Thanks simon.
Outlaw Flat Four 35
12.64 @ 106.25mph
« Reply #4 on: August 30, 2017, 21:28:45 pm »
Thanks simon.
Simon,
Yes none of that msd stuff will be needed now, I don't use cam synch on either of my dta set ups [E48 & S40], if you do wasted spark & batch fire on injectors its not needed
Rocket Ron
« Reply #5 on: August 31, 2017, 21:49:07 pm »
Thanks you both for your replies
 I had the speed shop stuff before, actually nice stuff.
Richie. Do you put the temp,sensor in the sump or at the filter head ?
Regards Ron
13.12 @ 101.84
« Reply #6 on: August 31, 2017, 22:06:18 pm »
In top of filter head
Rocket Ron
« Reply #7 on: August 31, 2017, 22:14:49 pm »
Ta
13.12 @ 101.84
broen messiaen
« Reply #8 on: September 03, 2017, 07:23:15 am »
does the dta also work with thedubshop crank kit?
anyone goes some experience?
« Reply #9 on: September 03, 2017, 09:01:48 am »
It can be set to work with just about any trigger arrangement. DTA is quite flexible and easy to work with once you get into it. Several guys here have shown great result with DTA.
-BB-
« Reply #10 on: September 03, 2017, 16:12:18 pm »
That's what I have on white 67, his hidden trigger/sensor and 36-1 wheel fixed to a Scat pulley
broen messiaen
« Reply #11 on: September 03, 2017, 20:59:13 pm »
thanks for the reply guys.
scored a S80 this week, so will give it a other try in the near future.
