October 03, 2026, 14:32:05 pm
arctic alice, early sixties cal-look
Topic: arctic alice, early sixties cal-look (Read 293381 times)
karl h
September 19, 2017, 11:36:55 am »
after a 69 bay, three 67s und a 72 i now want to do a car for myself (i promise)
my 61 panel project is on halt due to money and skill shortage (man, its expensive to restore a bus), i turned to the 63 shell i have on the rotisserie. this is how i got it:
(fairly) cheap, no doors/hoods/fenders included, besically just a lot of rust with a dented roof. but its the year of my birth, so i will give it a go
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Re: arctic alice, early sixties cal-look
September 19, 2017, 11:40:31 am »
i parted out a 59 that was too far gone, but the rest of the missing sheet metal was there, along with all the hardware to assemble a complete car.
the sunroof comes from this car, a metal only localy manufactured baja, that used a lot of Kübel parts (notice the Notek wartime drivinglight)
Last Edit: March 09, 2024, 12:11:52 pm by karl h
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
September 19, 2017, 11:47:58 am »
on saturday i will hop into the car with Mexx and get a 69 IRS pan from Oliver in upper Austria, this will be the foundation of the project.
i have lots of parts for this, it will use all the good parts i saved when i sold my oval ragtop:
993 front brakes with drop spindles and aluminium Brembo calippers
944 rears with 944 adjustable springplates
901 trans that Mexx regeared for me
engine will be a WBX 2.1 that is later going into the panel, but it will have to do until the 84x97 nickie motor ist done
paint will be arctic L363 with dark blue ragtop and light grey interior (i think)
i have 5.5/6 hearts i have redone and a set of early porsche steelies to make it a roller, but i wont tell the final wheelchoice yet...
Last Edit: January 21, 2020, 22:12:03 pm by karl h
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
September 20, 2017, 12:48:34 pm »
the body is really bad, lots of "repairs". i braced it before taking out the heaterchanels. right side chanel could be taken out by hand
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
vwhelmot
September 20, 2017, 14:33:42 pm »
Good stuff. Subscribed.
karl h
September 21, 2017, 13:15:29 pm »
thanx Lyndon!
looks like this now. about every replacement metal will be necessairy. why do i do this? i just have a soft spot for cars no one else would rescue
and to be honest: most of the stuff you get nowadays is pretty rusted through in this neck of the woods. why pay a lot of money for a car that looks better, but basically needs the same work to do it right
the best part is the front clip, it has been hit, but not too serously. i may be able to save it
Last Edit: October 06, 2017, 08:17:48 am by karl h
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
September 21, 2017, 18:16:40 pm »
Good project, looking forward to it developing. That nose does seem saveable - just gentle tapping, bit by bit.
karl h
September 21, 2017, 19:55:18 pm »
Thanx Neil for chiming in. There was actually a crease (the rusted vertical line) i was able to straighten out. Just having a glass of wine and loking at it now
Last Edit: September 21, 2017, 19:56:49 pm by karl h
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
vwhelmot
September 21, 2017, 21:11:58 pm »
It's because all beetles have a heart just like Herbie 😂
karl h
September 25, 2017, 13:09:12 pm »
since the rear bodymount on the drivers side had been removed with a cutoff wheel, i had to adress this wheelwell first to get a good solid mounting of the body on the rotisserie. i constructed two removable arms to the more forward positioned mountingholes in the body
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
September 25, 2017, 14:20:50 pm »
then i cut out the rusty part
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
September 25, 2017, 14:21:47 pm »
and welded in the repairpanel
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
September 26, 2017, 09:45:13 am »
some more sheetmetal came in. these are the better quality heater chanels, no seam on the bottom and no blind stamping of the later heateroutlet in the middle. they are empty though, no heater ducting inside, just a little bend under the vertical pipe. i think splits also had no heater ducting stock. since this will be no winter car i can live with that. when the heater is on it will dry out all of the moisture in the chanel,so this has a small benefit
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
September 28, 2017, 09:33:28 am »
the pan is here, a 69 irs from an automatic, rust free
i think i will have it sandblasted, but first i have to make a few adjustments: clutch tube and oil lines for a front oilcooler, as well as modify it to accept the porsche shifter and 901 fivespeed. some notches for the 944 adjustable trailingarms, remove the stock jackpoints (i hate these
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
Frenchy Dehoux
September 29, 2017, 04:51:49 am »
Great project i will follow your progress !!!
Frenchy
Doctor Detail ( Retired )
September 29, 2017, 06:33:47 am »
Pan looks like a good basis. I always chop the jacking points off too - they're just water traps. Are you sticking with the balljoint framehead or changing for linkpin? I remember being told years ago that the linkpin/IRS combination is the best handling one.
September 30, 2017, 15:35:17 pm »
Great project, keep us updated about the work. I like that Baja too
You certainly can get money for your project by selling these Kubel parts for a good price.
karl h
October 03, 2017, 07:53:26 am »
thanx for the interrest, guys!
i will keep the balljoint front beam, my dropped spindle/porsche brake combo fits it. sadly the rest of the "baja" was not mine, so no selling of parts....
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
October 09, 2017, 07:37:23 am »
passenger side wheelwell is repaired, both rear bodymounts are now functional
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
October 09, 2017, 07:38:24 am »
i was now able to take out the driversside heaterchanel
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
October 11, 2017, 06:55:25 am »
i cut off the stock jackpoints next and mounted the new heaterchanels to the pan with all screws. i did not tighten them all the way to be able to make minor adjustments.
after mounting the front beam to get the locating points of the body i will lower the body on the pan next
Last Edit: September 20, 2018, 09:59:49 am by karl h
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
October 12, 2017, 07:04:04 am »
beam is mounted
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
October 12, 2017, 07:04:55 am »
using my electric winch i lowered the body onto the pan. this simplyfies this action a lot for a one-man-show like me
Last Edit: October 12, 2017, 07:08:43 am by karl h
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
October 12, 2017, 07:08:04 am »
i will have to shorten the rear bodymounts, since it turned out that the 63 has these protruding further down. the 69 IRS pan has the later style, so there is 5cm to cut off. i was aware of this early body/late pan problem, but didnt know when the pans got the higher mounting points
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
October 16, 2017, 06:56:57 am »
shortened, the body now sits on the pan how it should
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
October 16, 2017, 06:58:45 am »
there is not much left where i can weld the body to the heaterchanels, but it will be enough: front firewall, a-pillar, b-pillar and the inner sidewall
Last Edit: April 04, 2018, 20:39:49 pm by karl h
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
October 16, 2017, 07:00:06 am »
before any welding can be done the doorgaps have to be checked, even with a brace. this is used to manipulate the a-pillar to the correct position
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
October 16, 2017, 07:03:29 am »
after some fiddling i ended up with acceptable doorgaps. heaterchanels are welded now.
the screw-plate of the a-pillar is very weak, missing its inner part of the pillar and the outer skin in the wheelwell, this will have to be adressed next
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
October 18, 2017, 07:45:40 am »
the a-pillars are now done from the inside
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
October 23, 2017, 08:29:50 am »
some more wok done to the left side heaterchanel/sidewall
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
