April 18, 2024, 22:50:21 pm
Umanisti
arctic alice, early sixties cal-look
5
8
Topic: arctic alice, early sixties cal-look (Read 101764 times)
karl h
Re: arctic alice, early sixties cal-look
Reply #60 on:
December 01, 2017, 11:45:12 am »
and tacked in place. sorry for some bad pics
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
Cornpanzer
Reply #61 on:
December 03, 2017, 05:30:09 am »
Very cool!
'67 Turbo Sedan
Ultra VW Contributor
karl h
Reply #62 on:
December 15, 2017, 08:03:27 am »
Hi Dave!
not much to show, but a lot of time consuming work: scraping off the undercoating under the tank and beneath the parcel tray. i have an appointment with the sandblaster today.
also started on the rear lid, first was to repair rust on the bottom
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #63 on:
December 18, 2017, 08:36:14 am »
off to the blaster, hope to get it friday
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #64 on:
December 18, 2017, 08:38:11 am »
some more work to the engine lid. louvers are from a 1302 hood. not easy to weld in since the curvature and position differs to early model hoods
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #65 on:
December 25, 2017, 12:26:11 pm »
body was blasted, but there was a little mishap with the primer
anyway, i have a lot of work to do on the pan
started by mounting the 901 fivespeed: cutting off the stock nosemount from the pan, cutting a window for the shiftrod and finding out a way to mount the rear of the trans to the aluminum mount
Last Edit: April 10, 2018, 07:53:49 am by karl h
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
thehanz DVK
Reply #66 on:
December 25, 2017, 14:08:48 pm »
Nice project again Karl , looking good
karl h
Reply #67 on:
December 25, 2017, 21:55:47 pm »
thanx!
modifications to the tunnel for the 5speedshifter (porsche 911 with shortshiftkit) are next: cutout opened and widened at the top
Last Edit: December 27, 2017, 08:02:52 am by karl h
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #68 on:
December 25, 2017, 21:58:58 pm »
some 2.5mm sheet for the base. oillines and 8mm fuellines are next before i weld it in. i will use the front cooler setup from an earlier project
Last Edit: December 27, 2017, 08:03:16 am by karl h
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #69 on:
January 03, 2018, 08:02:03 am »
clutch tube is welded in
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #70 on:
January 05, 2018, 08:43:39 am »
oil lines are prepared (but will be mounted after blasting), as well as two new 8mm fuel lines
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #71 on:
January 05, 2018, 08:44:37 am »
at the rear, right the cutout for the 901 shiftrod
Last Edit: February 22, 2018, 09:48:12 am by karl h
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
brewsy
Reply #72 on:
January 05, 2018, 21:56:13 pm »
Great work Karl.
Have you used oil lines through the spine before?
Does it heat up the interior much when you are on a long run or in the summer?
Marc
karl h
Reply #73 on:
January 08, 2018, 08:38:55 am »
i have used oillines in the tunnel before (a lot of people i know did it too) with no adverse effects. keep in mind i am not living in a a very hot climate.
one may try to keep the inspection cover on the framehead open and remove the rubber grommet around the shiftrod so there is air moved through the tunnel. maybe with a hose that takes air through the passenger side horngrill. just a thought...
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #74 on:
January 08, 2018, 08:42:42 am »
notches for the adjustable 944 springplates. i modified my plates with welding the front bolt to the inner springplate-part, so i only need the rear notch to be able to turn the adjuster
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #75 on:
January 10, 2018, 07:57:21 am »
all undercoating scraped off
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #76 on:
January 12, 2018, 22:29:00 pm »
Dropped the Pan off and took the body home. Epoxycoated
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #77 on:
January 19, 2018, 08:42:08 am »
closed a zillion pinholes on the body and some perforated metal on the bottom of the doors
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
Andrew
Reply #78 on:
January 19, 2018, 09:28:04 am »
Nice work, wish it had been that easy to paint under my pan....
vwhelmot
Reply #79 on:
January 19, 2018, 10:35:53 am »
Looking great!
karl h
Reply #80 on:
January 26, 2018, 07:57:06 am »
thanx Andrew and Lyndon
i closed all the holes after sandblasting, so the metal parts i have are ready for bondo work. the front hood and right front fender are still at the blaster (along with the pan). got a really nice stock front left fender from a friend and i am on the hunt for a right rear one.
since i dont feel like covering up the garage due to the dust involved by sanding everything just now, i will do the pan next. in a couple of days she should be ready, black epoxy and all. so i started on finding and painting the rest fo the chassis parts black
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
vwhelmot
Reply #81 on:
January 26, 2018, 09:08:58 am »
Getting it done quick mate, flying through it. Keep up the with the updates.
karl h
Reply #82 on:
February 01, 2018, 07:57:14 am »
pan is back. some pinholes too
, but hey - i have seen worse
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #83 on:
February 16, 2018, 09:15:45 am »
a stupid cold stopped me dead in the tracks, but now a im back at it. oil and fuel lines installed
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #84 on:
February 19, 2018, 07:53:25 am »
944 adjustable springplates are in
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #85 on:
February 19, 2018, 07:55:27 am »
...and the narrowed trailingarm with the 944 brake disc
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #86 on:
February 19, 2018, 07:57:41 am »
i modified an old 5x130 spacer to accomodate the torquemeister
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #87 on:
February 19, 2018, 08:00:06 am »
with the calipers on
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
Stevo_L
Reply #88 on:
February 19, 2018, 21:27:44 pm »
looking good!
karl h
Reply #89 on:
March 05, 2018, 08:29:27 am »
thanx Stevo!
new cunifer brakelines
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
5
8
