November 01, 2026, 22:10:47 pm
arctic alice, early sixties cal-look
6
7
8
Topic: arctic alice, early sixties cal-look (Read 304652 times)
karl h
Re: arctic alice, early sixties cal-look
Reply #180 on:
July 01, 2020, 11:34:46 am »
the longblock is assembled and i made a merged 1 1/2" header using an old Ansa header and a merged collector
engine is in to fit the exhaust and tin. very necessary, since the engine is an inch back due to the porsche 5speed
not going to use the 2" muffler in the pic, it fits the 1 3/4" merged header and would have to be modified. so i orderd a 1 3/4" oval muffler from CSP
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #181 on:
October 09, 2020, 18:30:13 pm »
bitch just doesnt want to get finished
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
Cornpanzer
Reply #182 on:
May 21, 2021, 03:34:24 am »
'67 Turbo Sedan
Ultra VW Contributor
karl h
Reply #183 on:
May 21, 2021, 07:03:07 am »
Hi Dave
uh-oh, dont remind me. i had a problem with the hydraulic lifters (waterboxer case - remember), one seems to not want to blow up
so after a lot of fucking around i put and AS cases 1600 in it to be able to drive it at last, since the wbx motor ist for this car anyway
should be done on the weekend
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #184 on:
July 14, 2021, 07:11:10 am »
a few pics, now its completed
still on porsche steelys with 175/70 Dunlops, got to get the Fuchs shod with my new Michelins
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #185 on:
July 14, 2021, 07:13:11 am »
still dicussing the new motor, but i will get back to my panel first
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #186 on:
July 29, 2021, 17:00:01 pm »
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #187 on:
September 10, 2021, 18:36:13 pm »
finished at last, first testdrive was pretty nice. before i changed the mastercylinder to a 944 unit
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
brewsy
Reply #188 on:
September 12, 2021, 19:54:02 pm »
Quote from: karl h on September 10, 2021, 18:36:13 pm
Nice!!
Was it worse to drive after you changed the mastercylinder then?
karl h
Reply #189 on:
September 12, 2021, 21:15:59 pm »
it worked with the stock one, but due to the axial movement of the discs the pads are pushed back a little and the original mc then had a very long way till it worked
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
Steve67
Reply #190 on:
September 13, 2021, 05:44:09 am »
Looks nice!
I have similar issues with the brake needing a lot of pedal stroke.
What brakes do you have on your car?
Does the 944 main cylinder fit without modification? What is the piston diameter?
Best regards Stefan
karl h
Reply #191 on:
September 13, 2021, 09:47:42 am »
i habe Brembo 993 front (early two piston aluminum calipers)
944 non turbo rear
you have to close the fifth hole at the bottom with a plug, the rest fits as is if you rebend the brakelines
i dont know the diameter, but its a lot more than the stock mc
i bought this one:
https://www.ebay.de/itm/324615336287
its heavy, there are aluminuim ones too, but they are more expensive
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
Steve67
Reply #192 on:
September 13, 2021, 10:29:21 am »
thanks, I will have a look
Chip
Reply #193 on:
September 13, 2021, 17:31:25 pm »
Looks fantastic! Well done
Brew 66
Reply #194 on:
September 14, 2021, 02:46:51 am »
Looks great, do you mind sharing who manufactured the front seats?
karl h
Reply #195 on:
September 14, 2021, 08:20:30 am »
i bought the seats used, they have a little patina...
the guy i bought them from said he got them from china. they look like cobra seats.
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
bean
Reply #196 on:
September 14, 2021, 11:49:24 am »
Quote
just what i was going to ask - they look just right
karl h
Reply #197 on:
January 14, 2022, 12:38:47 pm »
some more improvemts to the running gear
since i had 1° positive camber in the rear and there was not enough adjustment possible with the 944 springplates i had to cut and reposition the arms
before:
Last Edit: January 14, 2022, 12:40:39 pm by karl h
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #198 on:
January 14, 2022, 12:43:23 pm »
first, to get an even measurement i bolted two steel angle to the lower attachment points of the torsion tubes from the inside, left and right
so i could put a straightedge across the pan that clears the transmount to get the car level
Last Edit: January 14, 2022, 13:08:28 pm by karl h
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #199 on:
January 14, 2022, 12:47:18 pm »
next i took a measurement and determined the initial angle, then i removed the rear brakes and the trailingarms from the car. the snubbermounts have to be cut off first.
then a cut parallel to the axle was made, leaving onle the lowermost part were the twwo trailingarm parts meet intact
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #200 on:
January 14, 2022, 12:59:16 pm »
i used the floorjack to move the stubaxle up to these degrees, calculating upon lowering the car down its weight would get me the desired camber
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #201 on:
January 14, 2022, 13:01:39 pm »
i tacked the arm inside the car, then removed it and welded all the way around, followed by the reinstallation of the snubber mounts
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #202 on:
January 14, 2022, 13:02:42 pm »
after: 1° negative camber
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
brewsy
Reply #203 on:
January 14, 2022, 18:53:26 pm »
Nice job!!
karl h
Reply #204 on:
January 14, 2022, 19:13:07 pm »
thanx
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
bug
Reply #205 on:
January 18, 2022, 22:02:03 pm »
Very nice and interesting topic about the IRS arms that you narrowed.
Which tire size you have in the back?
Flat 6 or deep6 Fuchs?
Thank you
karl h
Reply #206 on:
January 19, 2022, 11:39:19 am »
the arms are narrowed 25mm per side, the 944 brakes move the wheels out the same 25mm
fuchs are deep 6 with 205/65 michelins
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #207 on:
March 03, 2022, 12:47:45 pm »
setting up geometry front and rear. i also did a different 2" muffler
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #208 on:
April 25, 2023, 09:12:30 am »
new look with Gasburners
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
Steve67
Reply #209 on:
April 25, 2023, 15:55:36 pm »
Looks great on the Gasburners!
6
7
8
