September 22, 2026, 04:04:25 am
| | |-+  DCNF carbs
Pages: [1] 2 Print
Author Topic: DCNF carbs  (Read 48327 times)
Rune
SCC Crew
Screwdrivers #7
« on: October 10, 2007, 19:02:12 pm »
Just wondering, when did people start putting these carbs on theyr motors? Are they a part of the early cal look, or more an early to mid 80s thing? I have noticed that there are some cool old school intakes and filters out there for them, but I don't think I have seen them in use on any of the early cars..
And another thing, what is the modification that makes the "Berg specials" so special..?
« Reply #1 on: October 10, 2007, 19:15:57 pm »
i've got the 1976 HotVW cal-look issue, and i remember at least one engine sporting DNCF carbs.
so, i'm guessing they're not an 80-ies thing.
« Reply #2 on: October 10, 2007, 19:23:50 pm »
DCN's came first. I think the DCNF's were introduced in about '75. In a bug you have to trim the edge of the compartment to clear filters. I used Berg 42 Specials in my type 3 and I think they are the perfect carbs for pancake engines because of the short profile. Ive heard 40s have the wrong circutry, and 44's are just as good as 42's. For driveability and mileage, I dont think there are better carbs for a big motor.
« Reply #3 on: October 10, 2007, 19:27:57 pm »
like this one zack Huh
« Reply #4 on: October 10, 2007, 20:08:51 pm »
That's what I've been running for over 15 years.  They work great if you don't have to look like everyone else with 48s.
« Reply #5 on: October 10, 2007, 20:27:24 pm »
i reckon those speedwell showed would look the bollocks  Grin
Rune
SCC Crew
Screwdrivers #7
« Reply #6 on: October 10, 2007, 20:28:24 pm »
I have a little motor with 42 Berg specials on the way for my oval, hopefully it will take me to some of the euro shows next summer..
« Reply #7 on: October 10, 2007, 23:58:45 pm »
I would go for the Early 3 bolt DCN's - I only use 1 Wink but it is  F"*KIN AWSOME  Smiley
They are SO simple I always describe them as BIG twin choke solex's  Wink Smiley
« Reply #8 on: October 11, 2007, 02:04:08 am »
they started Running 36 DCN's,then 40 DCN's in early 70's which were both 3 bolt  then 40 DCNF's, and 42 DCNF's, and then the 44 DCNF which were all 4 bolt. here's the specs on Berg Specials The Berg 42mm Weber Special carbs are redrilled and circuited to match specific VW engine applications. Each set is calibrated by our experts to work from idle to top RPM with the correct fuel flow rate and progression with all Berg parts. This ensures proper running throughout the RPM range without flat spots, lean, or rich conditions. Gives maximum performance with best fuel efficiency. Gives more available fuel/air for maximum cooling than any other Weber or Dellorto.
« Reply #9 on: October 11, 2007, 02:11:37 am »
I know that Steve Hollingsworth of V.W. Performance in Phoenix can make your DCNF's "Special". He is a longtime personal friend of the Berg's, and knows the in's and the out's.
lowfastbus
WUNDERWAFFE
« Reply #10 on: October 11, 2007, 20:30:03 pm »
We have a Ferrari Dino at work that uses 3 off those...
http://dragvws.skynetblogs.be
WUNDERWAFFE
The Knuckle Buster
« Reply #11 on: October 11, 2007, 22:11:11 pm »
See even Ferrari thought they were COOL  Wink Smiley
ESH
« Reply #12 on: October 11, 2007, 22:16:33 pm »
Ferrari think rust is cool!  Grin
« Reply #13 on: October 11, 2007, 22:31:13 pm »
Not the ones I like - they were all hand beaten aluminuin Wink Smiley
I worked on the one in the middle  Grin
ESH
« Reply #14 on: October 11, 2007, 22:41:19 pm »
They're not aluminium underneath.
I just got to thinking, electricity, steel, moisture and aluminium aren't a good mix in terms of corrosion right? Are Italian electrics designed with this in mind and therefore don't carry either current or voltage by design?
 Grin
« Reply #15 on: October 11, 2007, 23:17:46 pm »
tell me about it - the welding on the steel chassis was crap  Roll Eyes BUT the Oval tubing they used was pretty COOL Smiley
I'm guess your not a big fan of ferraris then dude  Wink Smiley
ESH
« Reply #16 on: October 11, 2007, 23:30:51 pm »
I love them up to a point, the problem I have is that many of the people that dream of owning them fall out of love when it comes to the bills and it's all to do with stupid stuff that ends up costing way more than it ever needed too.
Bottom line, give me something German any day of the week.  Smiley
« Reply #17 on: October 11, 2007, 23:54:22 pm »
Couldn't agree more dude - I just Love there looks - Give me something German anyday Smiley
Any way back to the Carbs  Wink Smiley
Fonz
Still struggling with speed humps!
« Reply #18 on: March 31, 2008, 15:13:07 pm »
What part of the 40s circuitry makes them wrong?
Frenchy Dehoux
« Reply #19 on: March 31, 2008, 16:50:54 pm »
    I had 42 DCNF 9 on my daily driver back in 1975 until 1980 on my 1973 beetle and they have a lot of bottom end easy to rebuild do not need to be a scientist to figure them out. Good gas mileage carb. I have an early set of 42's Berg special with linkage and manifolds .I also found an early pair of velocity stacks which I bought from Shubee last year very hard one to find.
     Frenchy
Doctor Detail ( Retired )
« Reply #20 on: March 31, 2008, 17:00:47 pm »
Here's what Gene told me many years ago.  Earlier versions of the DCNF has too large idle circuit to work properly.  He said that only the 42s and 44s had a small enough idle circuit that they could be opened up to work properly.  Now I know that many people have used the 40 DCNFs with success, but that is what Gene Berg said back in the late 80s.  I have run both 42s and 44s with great success.  They are smooth and deliver good performance and mileage.  They just don't look like IDAs otherwise they are great for a street car.  I sold the only pair of IDAs I ever owned without ever using them.  Besides the DCNFs are early Cal-Look and I still remember Bil Schwimmer driving his car to Phoenix with DCNFs on it.
« Reply #21 on: March 31, 2008, 17:26:18 pm »
Heres a Picture of My 42 DCNF's with the early rare Stacks Frenchy refers to.
« Reply #22 on: March 31, 2008, 17:41:14 pm »
I have a set of those carbs along with the stacks NIB someplace... saving them for a T3 project.
« Reply #23 on: March 31, 2008, 17:51:45 pm »
LMAO Rick You dont need a Type 3 Project its been 20 years for 67 its going to take an act of God" to get it Done lol  if you wait much longer you will have to play Tug of War with all the Spider Webs Again  Grin Grin Grin
jhicken
« Reply #24 on: April 01, 2008, 22:22:13 pm »
Here's a shot of my '67 [circa 1977] with a 1776 sporting a pair of 42dcnf's.
Vauhn Rollings helped me set these up. Ran smooth as silk. My best time at OCIR was 15.07 and if I was light on the throttle, I could almost get 40mpg [long hiway trips]. No bullshit.
-jeffrey
« Reply #25 on: April 01, 2008, 22:35:19 pm »
-jeffrey
Now that is a COOOOOOOL looking motor  Smiley and 1977 is when I was born  Wink Smiley
« Reply #26 on: April 02, 2008, 02:26:39 am »
I had the cast aluminium stacks but I traded them straight up for a pair of Bergs Roll Eyes Then cut them waaayy down to fit in the short aircleaners of my type 3 Wink
« Reply #27 on: April 02, 2008, 20:51:02 pm »
One thing you might take into consideration, the DCN, DCNF carbs were originally designed to be used on Italian vee-configuration engines, nestled between the cylinder banks, with the throttle shafts oriented perpendicular to the axis of the engine's crankshaft. I believe the 40DCN was orignally utilized on the Ferrari 275GTB/4 V12 and the 42DCNF was utilzed on the Maserati/Citroen 2.7L V6 (in the SM and the Maserati Merak). All of these applications ran the throttle shafts 90 deg to the crank axis. Anyway, the floats on these carbs were designed to ride on the car as they did on the Ferrari, Citroen, etc. On a VW they are oriented 90 degrees from how they should be. I have heard from guys that have run them that you'd go into a long, fast corner and the motor would shut off, due to empty float bowls. Even the Berg catalog alludes to this problem and mentions that for off road or slalom use, the IDF is a better carburetor. A friend/customer of mine up north worked up a dry-sump float bowl system for DCNFs on his off road stuff in the mid 70's and it cured the problem and he "ate those Zenith pussies alive."
48IDAs aren't just for looks. They hold an amazing volume of fuel (I can run the car down the street on gentle throttle to the grocery store without turning my Holley pump on), they wake up VW motors that "need" them, they are easier to work on than any carburetor I've played withm, they are as simple a child's Lego set, plus they make undeniable horsepower. On the downside, they are so BIG that they make working around them a little aggrivating. But which dual carbs on a Type 1 DON'T?
« Reply #28 on: April 02, 2008, 22:16:29 pm »
Hey Jim I seem to remember you pointing this out before and thats why I only use ONE and it 90degs compared to the crank  Wink Smiley
I have said it before and I will say it again - DCN's are F$%KIN AWSOME!!!!!!!!!!!! Wink Smiley
I'mgonna start another thread  Grin
« Reply #29 on: April 02, 2008, 22:58:34 pm »
I have driven with my DCNFs many times into long sweeping corners with nary a problem.  Where it locks one float open and one closed my experience says it is on acceleration from a stop and making a hard turn at the same time.  That is hard acceleration not just driving away.  Otherwise they are the smoothest dual carb set up I have experienced.  I have and have used both 42s and 44s.
Pages: [1] 2 Print
