October 13, 2026, 00:33:47 am
| | |-+  Type 4 mains and flange crank cut
Author Topic: Type 4 mains and flange crank cut  (Read 8619 times)
« on: October 13, 2017, 20:20:46 pm »
Hi guys,
Is there anyone in the U.K. that can cut an Ali case for type 4 mains and flange crank?
Lee
« Reply #1 on: October 15, 2017, 11:35:54 am »
I would ony bore the sealing for the flywheel and use adapter bearings for the crank
« Reply #2 on: October 15, 2017, 12:37:44 pm »
Thanks Udo,
Where can I buy the adaptor bearings? That will work for all type 4 mains?
Lee
LGK
« Reply #3 on: October 15, 2017, 13:50:13 pm »
Hello Lee,
You need the BMW bearings ,engine bearings needs to be machined (narrower) and setup for the thrust,either on the middle saddle or the flywheelside.
you can also do the mod for the thrust on bearing number 3,but this is more complex  as you need to machine the straight cut gear for this.(Also i've done it on 3 cases in the past,and i always worried a bit about the "flex" in the crank",but i was surprised how well the bearings looked when i took the very first setup apart years later...)
Only a few people in Europe are capable of doing these kind of setups.
I can do either setup,or you can contact Udo Becker in Germany,he's doing a neath setup too with the BMW bearings,or JPM in sweden he's also capable of doing this conversions.
In the UK i guess only Pete Englezos is performing this kind of modifications,also Richie Webb may have some contacts but others may chime in on this .
Cheers Steve
pq
« Reply #4 on: October 15, 2017, 14:10:00 pm »
https://m.facebook.com/Reichspeed-aircooled-320391747980641/  Huh
« Reply #5 on: October 15, 2017, 17:11:26 pm »
Thanks guys, gives me some leads Wink
Tufty65
« Reply #6 on: October 15, 2017, 22:58:21 pm »
Danny @ Reichspeed can do it, he did my rear thrust conversion etc, look on the FB page if you have it.
Outlaw Flat Four 35
12.64 @ 106.25mph
spoolin70
« Reply #7 on: October 16, 2017, 06:47:32 am »
It was posted one before yours by pq Wink
Tufty65
« Reply #8 on: October 16, 2017, 17:05:50 pm »
I know, I was seconding his work.
Outlaw Flat Four 35
12.64 @ 106.25mph
