September 24, 2026, 07:12:38 am
csp python header.
Topic: csp python header. (Read 7286 times)
Bad bug
csp python header.
November 05, 2017, 13:57:05 pm »
Good day Guys,
Has anyone used this header on a performance engine. I am building a 2.2ltr oxyboxer with 9.5:1 compression running webcam 86b with the new los panchitos and a set of dellorto 48mm trijet carbs. would love to know what the power is like with this header.
https://www.csp-shop.com/en/exhaust-heating/csp-python-exhaust-system-type-1-251-101-038-22309a.htmlv
Re: csp python header.
November 05, 2017, 22:18:08 pm »
I run one on my 1967 Sedan, 94 x 78, 42 x 37, Weber 48mm, 86B. I run the 42mm version.
Larry S
November 06, 2017, 18:26:01 pm »
Jim,
Not to hijack this thread but I see you run 94mm pistons and cylinders, I am starting a engine build for my car and trying to decide which ones to run, 90.5's etc. any insight? weekend car not a daily driver, gets hot here in the Midwest in the summer. looking at panchito heads 40 x 35.5, 48 ida's.
Thanks,
Larry
Bad bug
November 07, 2017, 03:34:48 am »
Quote from: Jim Ratto on November 05, 2017, 22:18:08 pm
Jim what is the performance like.
Bad bug
November 07, 2017, 03:36:03 am »
Quote from: Larry S on November 06, 2017, 18:26:01 pm
Jim,
Thanks,
Larry
You planning on running all the cylinder tins.
Larry S
November 07, 2017, 14:15:20 pm »
Yes, I will run all the tins, I have a VW Thing shroud I can use also.
November 07, 2017, 17:51:05 pm »
Quote from: Bad bug on November 07, 2017, 03:34:48 am
Torque comes on harder and later, compared with 1-3/4" traditional merged with A1 Magnaflow. Engine runs cooler. I think I posted the differences somewhere here. Needed 1 size up larger idle and main.
Bad bug
November 10, 2017, 03:22:16 am »
Quote from: Larry S on November 07, 2017, 14:15:20 pm
Good decision
