July 25, 2026, 20:07:41 pm
| | |-+  csp python header.
Author Topic: csp python header.  (Read 6817 times)
Bad bug
« on: November 05, 2017, 13:57:05 pm »
Good day Guys,
Has anyone used this header on a performance engine. I  am building a 2.2ltr oxyboxer with 9.5:1 compression running webcam 86b with the new los panchitos and a set of dellorto 48mm trijet carbs. would love to know what  the power is like with this header.
https://www.csp-shop.com/en/exhaust-heating/csp-python-exhaust-system-type-1-251-101-038-22309a.htmlv
« Reply #1 on: November 05, 2017, 22:18:08 pm »
I run one on my 1967 Sedan, 94 x 78, 42 x 37, Weber 48mm, 86B. I run the 42mm version.
Larry S
« Reply #2 on: November 06, 2017, 18:26:01 pm »
Jim,
Not to hijack this thread but I see you run 94mm pistons and cylinders, I am starting a engine build for my car and trying to decide which ones to run, 90.5's etc. any insight? weekend car not a daily driver, gets hot here in the Midwest in the summer. looking at panchito heads 40 x 35.5, 48 ida's.
Larry
Bad bug
« Reply #3 on: November 07, 2017, 03:34:48 am »
Jim what  is  the performance like.
Bad bug
« Reply #4 on: November 07, 2017, 03:36:03 am »
Jim,
Larry
You planning on running  all the cylinder tins.
Larry S
« Reply #5 on: November 07, 2017, 14:15:20 pm »
Yes, I will run all the tins, I have a VW Thing shroud I can use also.
« Reply #6 on: November 07, 2017, 17:51:05 pm »
Torque comes on harder and later, compared with 1-3/4" traditional merged with A1 Magnaflow. Engine runs cooler. I think I posted the differences somewhere here. Needed 1 size up larger idle and main.
Bad bug
« Reply #7 on: November 10, 2017, 03:22:16 am »
Good  decision
