October 28, 2026, 20:23:49 pm
Hanibal1
Fubar 2
Topic: Fubar 2 (Read 20695 times)
vwhelmot
Fubar 2
November 28, 2017, 12:47:21 pm »
I suppose you can call this part two of the rebuild. I will post up a lot more content early next year but for now I will show some of the stuff I have been getting on with . Tinware , especially aftermarket stuff has always been hit and miss. The tinware fitted to the motor when I bought it was mostly Scat stuff to which I adapted some original vw cylinder shrouds and other pieces. This time round I`ve mostly kept what was there apart from the front breast plate. The fan housing was in good shape but had holes drilled into it for the Berg linkage and the coil mount and as I`m not using that linkage anymore they had to be welded up etc. The seam on the back was next to go, half way round I did wonder why I was doing this but it looks nice and clean now.
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
It did take a while to keep it flat
Untitled
by
lyndon creamer
, on Flickr
Next was the cylinder tins. I hate how the factory just folded over the edge and spot welded the three pieces together so I cut them up and welded them back together creating a nice smooth edge.
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
I did buy a set of Danny Gabbards end pieces but to be honest when I saw them I thought I could just mod mine to a similar style.
Untitled
by
lyndon creamer
, on Flickr
I made the lip flow the whole way around like this
Untitled
by
lyndon creamer
, on Flickr
By this time I had tacked the pieces together. I had to wait a while to finish these as my motor was still away at Bishops racing engines being built.
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
vwhelmot
Re: Fubar 2
November 28, 2017, 12:59:43 pm »
Making the oil cooler shroud fit without any gaps has been a challenge. Cut and welded the curve at the top and the flange.
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
I`m fitting the thermostat flaps back into the shroud, locked in the open position as it directs the air to the right place. I lightened them quite a bit .
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Here you can see that I`ve made a little tunnel for the plug wires to go through without touching the case
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
baz
Re: Fubar 2
November 28, 2017, 21:12:23 pm »
Top class work as usual. Loving the tinware mods
I will prevail.
karl h
Re: Fubar 2
November 29, 2017, 07:55:14 am »
love to watch your work, keep the pics coming!
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
glassback kid
Re: Fubar 2
December 01, 2017, 14:54:59 pm »
Excellent great to see updates, once again great workmanship, looking forward to more
sonic
Re: Fubar 2
December 01, 2017, 15:06:46 pm »
Nice , aftermarket parts do have a lot to desire
Rgs
vwhelmot
Re: Fubar 2
December 01, 2017, 17:09:27 pm »
There is a LOT of aftermarket parts available that are complete rubbish from panels to rubber to fixings to just about every aspect of the ingredients! The amount of stuff I`ve bought twice because it was not up to scratch is unreal. Some of it wasn't cheap either. I will update soon , still trying to sort my Flickr account and trying to retrieve photos from Photobucket.
vwhelmot
Re: Fubar 2
December 04, 2017, 11:29:21 am »
Random stuff
Rear axle bearing housing, I pressed out the axle tube which was a job in itself so I could detail the housing. Lots of hand filing and sanding and a little bit of lightening.
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
People don't realise how much time stupid thing like this takes. Hours and hours of work and its a bearing housing of all things. Since the final picture was taken I repainted them as I wasn't happy about the finish
vwhelmot
Re: Fubar 2
December 04, 2017, 11:56:25 am »
Pedals. I will admit to copying Dude with his idea of rose jointing the throttle linkage, so all monies will be past onto him
The throttle pedal hinge was something I had made seventeen years ago for the first resto. I then thought it was a good idea to drill the floor pan and bolt the pedal through it but for this time that wasn't going to happen. I kept the hinge as it worked and is a lot more solid than the standard vw item which not only looks gash but is a bit agricultural too.
Untitled
by
lyndon creamer
, on Flickr
The stop plate was part of the original design
Untitled
by
lyndon creamer
, on Flickr
The pedals as they were
Untitled
by
lyndon creamer
, on Flickr
I love the look of drilled pedals
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Yes ive heard that drilling them makes them weaker but I`m not really planning on driving it much anyway
Untitled
by
lyndon creamer
, on Flickr
Lots of smoothing went on.
Untitled
by
lyndon creamer
, on Flickr
The brake pedal plunger pivot was very worn so I made a new one and pressed it in.
Untitled
by
lyndon creamer
, on Flickr
Drilled the plunger too
Untitled
by
lyndon creamer
, on Flickr
Trial fitted. I had to do something with the throttle shaft stop. Vw just crimped it to stop the shaft being pushed too deep into the tube. That wasn't good enough so I modified it with a welded washer
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
The mounting plate was later modified too
Untitled
by
lyndon creamer
, on Flickr
The floor pan had this pressing for the original throttle pedal so I had to cut it out to make the area flat.
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Cleaned up the hinge and modified it slightly
Untitled
by
lyndon creamer
, on Flickr
Welded on from underneath
Untitled
by
lyndon creamer
, on Flickr
Drilled some more holes
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
I used two male rose joints and machined up an aluminium adjuster so theoretically its different to Dudes set up
Untitled
by
lyndon creamer
, on Flickr
Again, hours and hours into this but I think it was worth it for the look.
Untitled
by
lyndon creamer
, on Flickr
Last Edit: December 04, 2017, 11:58:14 am by vwhelmot
Re: Fubar 2
December 04, 2017, 20:48:21 pm »
you say that it takes hours, but the way i see it it takes hours to make it very nice, i would have done it in minutes, making scrap
very nice work!
vwhelmot
Re: Fubar 2
December 06, 2017, 11:20:59 am »
Steering box. The box that was on the car when I bought it back was the same TSW one that I had installed in the first restoration way back and to be honest was still in useable condition but there was one problem..... it was a TSW one. The search went on for a genuine VW box and after a fair amount of on line searching I found one. It looked tatty on the outside but actually felt slop free when turning the input shaft. The worm gears were in absolutely superb condition as were the bearing surfaces. So many of these in the past were worn out, especially the ball race surface but this one is like new. The casting is really rough , even on the genuine VW ones so there was loads of hand tool smoothing to be done.
Untitled
by
lyndon creamer
, on Flickr
Hot tip, leave the old seals in place to act a paint mask
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Blasted
Untitled
by
lyndon creamer
, on Flickr
More hand smoothing
Untitled
by
lyndon creamer
, on Flickr
It had a strange cast near the bottom which served no purpose only to look ugly so I smoothed it round to match the rest of it.
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
High build primed, I masked off the VW logo too.
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
First coat of black metalflake
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Flatted
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
New seals installed
Untitled
by
lyndon creamer
, on Flickr
The input shaft was rusty and its made from heat treated extra hard steel so I had to spin it on the lathe and linish it with a belt sander to super fine grades to polish it up , then seal it with metal sealer afterwards.
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Going back together
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Chrome going on
Untitled
by
lyndon creamer
, on Flickr
I had the cap chromed and then painted the deep recesses black after.
Untitled
by
lyndon creamer
, on Flickr
I changed the brass bolts for polished stainless after this.
Untitled
by
lyndon creamer
, on Flickr
Chromed Pitman arm after lots of smoothing etc.
Untitled
by
lyndon creamer
, on Flickr
Untitled
by
lyndon creamer
, on Flickr
Bottom clamp beautified
Untitled
by
lyndon creamer
, on Flickr
It got painted the same black metalflake too
Untitled
by
lyndon creamer
, on Flickr
So that's the steering box nearly done. Onto the next
brewsy
Re: Fubar 2
December 06, 2017, 12:04:51 pm »
Beautiful!
Did you remember which way round the clamp goes though? There's a 13 and 14 marking (which you probably polished off
Bentley will tell you which is which but ones for Beetle and ones for KG.
vwhelmot
Re: Fubar 2
December 06, 2017, 12:31:37 pm »
Haha I knew there was a difference, this is definitely a bug one, I compared it to a couple of other scrap ones I had.
baz
Re: Fubar 2
December 06, 2017, 15:42:11 pm »
Same clamp on kg and bug, the slots on side that locate on the dimple on beam gives correct steering box angle, goes one way for bug and other way for kg.
Not that you look like you need any help
unless you've made the slots even each side
I will prevail.
Andrew
Re: Fubar 2
December 06, 2017, 18:33:38 pm »
One word, "Amazing"
brewsy
Re: Fubar 2
December 07, 2017, 16:55:12 pm »
Here you go...
Last Edit: December 07, 2017, 16:56:44 pm by brewsy
vwhelmot
Re: Fubar 2
December 08, 2017, 09:25:36 am »
Not needed , I should have welded the notches up
Re: Fubar 2
December 08, 2017, 12:57:27 pm »
Quote from: baz on December 06, 2017, 15:42:11 pm
Every day's a school day! I didn't know that and I've had (and changed steering boxes on) both!
brewsy
Re: Fubar 2
December 08, 2017, 13:16:06 pm »
Quote from: Neil Davies on December 08, 2017, 12:57:27 pm
Sorry to hijack Helm..
Neil I recently bought the Bentley after years of just having the Haynes (and hearing all the Samba peeps quote it as the bible) and reading it through gives LOADs of insight into our old cars..
