October 01, 2026, 19:46:21 pm
Comp eliminators, can they be bored for 96.5?
Topic: Comp eliminators, can they be bored for 96.5? (Read 18148 times)
December 02, 2017, 09:49:51 am »
As in title, is it possible?
wph
Re: Comp eliminators, can they be bored for 96.5?
December 02, 2017, 23:35:22 pm »
I think they are, I have a set of OLD Superflow heads and they are going to be 98,00mm but I had them welded for WBX bolt pattern.Barrel OD is 106.5 before breaking through casting.
We are also running a set of custom bored/honed Jaycee barrels on older Angle Flow castings / type 1 pattern with 96.9 bore...
Pekka
December 03, 2017, 16:31:11 pm »
Yes you can do that , if you have relocated bolt plattern you can go up to 101,6.
www.Udobeckertuning.de
December 03, 2017, 17:30:18 pm »
Thank you Udo, the heads are already built up. If I remove valves etc and have them bored will I be ok? I won't have to relocate valve seats etc?
Jonny Grigg
January 10, 2018, 22:10:50 pm »
Out of interest Lee, what pistons any cylinders do you have for 96.5?
Jonny
No Compromise. O/FF111
January 10, 2018, 22:14:54 pm »
Hi Jonny,
I got offered a case that was a 96.5 bore, it was a thinking out loud question!!
January 11, 2018, 19:05:53 pm »
For 96,5 you do not have to remove anything . A case with 10mm threads for example can get bored to that cylinder - super street rules :-)
January 11, 2018, 21:18:44 pm »
So a 10mm head stud case can accommodate 96.5?
January 13, 2018, 18:16:54 pm »
If the 10mm thread is right in the case without savers it works
bedjo78
January 14, 2018, 11:04:52 am »
Quote from: leec on January 10, 2018, 22:14:54 pm
Hi Jonny,
Interested though ... is it mag case ?
volkskris
January 23, 2018, 11:52:16 am »
Quote from: Udo on January 13, 2018, 18:16:54 pm
So what is actually done to get that bore to fit Udo?
January 29, 2018, 19:25:47 pm »
Only 10mm threads in the case , like aluminiums . No bigger inserts
