September 22, 2026, 15:26:16 pm
| | |-+  Axles and spacers
Author Topic: Axles and spacers  (Read 6859 times)
Richierich56
« on: December 30, 2017, 16:05:04 pm »
Hi all - need a bit of advice if possible please.
I'm currently running 205/65/15 tyres on the rear of my Oval with 26 11/16" length race axles.
I want to fIll the arch a bit more with the tyre and was thinking maybe i'll run a 10mm spacer to get the tyre out a bit more. My question is, will that stress the axle too much - effectively adding length?
Should have said, I would just run a wider tyre but I'm already only a couple of mm off the adjuster on the spring plates with the 205/65's hence thinking about spacers
« Last Edit: December 31, 2017, 00:03:34 am by Richierich56 » Logged
« Reply #1 on: December 31, 2017, 01:14:11 am »
If I'm thinking of the right car, you've got Gasburners? Maybe a swap to Fuchs with a different offset would allow you to position a wider tyre where you want it?
« Reply #2 on: December 31, 2017, 10:31:45 am »
I can't see a 10mm space causing any issues. Deep six fuchs with short axle always need a spacer IMO to get the wheel to sit right in the arch
Andy
« Reply #3 on: December 31, 2017, 10:45:27 am »
I have run with 10mm spacers for years with no problems and have seen spacers on other quick cal lookers. I think the area I would pay attention to , would be the wheel studs, as they have the extra leverage acting on them, high quality m14 press in studs might be worthwhile.
Richierich56
« Reply #4 on: December 31, 2017, 15:41:13 pm »
I have m14 press in studs already in so thats no prob. Interesting about the Fusch's Neil and Lee (yep, got the right car Neil, I'm on GB's) I have been toying with the idea of changing to those. The offset quite different is it?
« Reply #5 on: December 31, 2017, 17:37:20 pm »
Burners do tuck in a bit more iirc. I like the burners on your car, experiment with spacers, just make sure your studs are long enough Smiley
baz
« Reply #6 on: December 31, 2017, 19:29:58 pm »
Handy chart for reference, mahle gas burners are same as 5.5 fuchs I think or maybe 45mm vs 42mm et.
I will prevail.
« Reply #7 on: January 06, 2018, 14:08:06 pm »
Mahles & 5½" Fuchs both have 42mm offset.
