September 16, 2026, 17:16:31 pm
Bad Habit
Flanged Crankshaft - which brand to choose?
Topic: Flanged Crankshaft - which brand to choose? (Read 21641 times)
Stev
January 08, 2018, 19:53:34 pm »
Hi guys,
i start building my engine. Iīm looking for a flanged crankshaft but not sure which is the right for my setup. I heard a lot of good things about Scat and Bugpack, not sure if i ever heard about a flanged crank from AA Performance. I have an offer for a Scat and an AA, the Scat is much more expensive and now the question to you, which one should i use?
The engine:
84-88mm crankshaft
4" bore
MS 230
Raptor CAM
EFI
Python
Thanks a lot :-)
Regards
Steven
ps: if there is anybody who would like to sell a new flanged crank with all type 4 Mains und 84 - 88mm you a very welcome to write me a pm.
Last Edit: January 08, 2018, 19:59:53 pm by Stev
Looking for a flanged crankshaft, all type 4 main bearings and a flywheel for KEP clutch. Stroke 84 till 88. The bigger the better ;-)
UltraOrange67-2443
Re: Flanged Crankshaft - which brand to choose?
January 08, 2018, 22:03:19 pm »
I would go for the Scat.
High quality part.
I'm building a 2919 using a Scat pro drag lightweight Crank.
Cheers, Nick
1967 1200 2920cc EFI
January 09, 2018, 20:37:42 pm »
If you want to be on the save side i would recommend the same - billet light weight scat , most they have 86 in stock . we are testing an AA but do not have any results on a smaller engine
www.Udobeckertuning.de
Stev
January 09, 2018, 20:51:47 pm »
Hi and thanks for your reply.
I canīt find the Scat light weight on the webside.
- Udo, why do you prefer the "light weight" version? Do you have one in Stock?
I have to ask which scat version the guy offered me.
2 vote for scat
0 Bugpack
0 AA
January 11, 2018, 19:08:08 pm »
No , i do not have them in stock- i order them for special orders . They have a part number at Scat for the"super light"
LGK
January 11, 2018, 20:23:34 pm »
Hello,
I have the scat cranks in stock.
82-84-90-92 strokers is what i have on the shelf "flanged style".
The 90 stroker is all type 4 mains,the other ones are only type 4 "middle".
No experience with AA. I prefer the CB cranks or DPR cranks(if available) ,but SCAT is on top.
We are also working on a brand new crank,made in europe,on a swedish forging.More on that later.
Best rgds
Steve@flat4to6.com
https://www.facebook.com/StevesVwShop
http://www.flat4to6.com
http://www.woodford-trailers.eu/
Stev
January 11, 2018, 22:34:09 pm »
Hi,
steve, wrote you a mail about the 90mm.
cheers
Steven
January 12, 2018, 16:07:39 pm »
Quote from: LGK on January 11, 2018, 20:23:34 pm
Best rgds
Steve@flat4to6.com
COOL!
I ordered the first Gene Berg crank to Sweden in 1977. (Welded)
Then I borrowed it to Christer Lindström at Beta Racing in Avesta and introduced him to Gene. He was key in working with Gene and Bofors steel to start up the famous business of Swedish crank forgings and US machined in Orange CA.
Happy to see the story in having some kind of continuation. Good luck!
Ahhh by the way, at some time I also introduced Jake Raby to the posibilities on German or Swedish forgings for TIV cranks. Volume was too low and it never materialized.
Some of my cars:
January 13, 2018, 18:15:58 pm »
For street use those AA forged seem to work. i build some Type4 engines with it also a 3,0 for circuit racing with 260 hp. works well so far
Stev
January 14, 2018, 21:13:53 pm »
Hi Udo,
itīs an AA Billet 88mm, but i think i will take the scat. i talked to eddie from scat, he told me that the billet version they offered on ther website is the "light weight" version without the holes.
By the way, scat rods are good enough for my setup? I think the rev limiter will be at 6500.
Steven
Roman
January 15, 2018, 10:08:26 am »
I have Scat rods in my JPM built 2387 producing 300+ hp.
Upgraded with Carrillo bolts though.
January 15, 2018, 14:59:06 pm »
Quote from: Stev on January 14, 2018, 21:13:53 pm
Hi Udo,
Steven
Hi Steven,
So how much is the billet light weight Scat flanged crank? Part number for 86 version?
January 15, 2018, 19:02:59 pm »
Hi Udo,
Steven
. If you will not rev that high I would recommend the one without the holes for light weight. It is much more expensive . I have it for making 9000 + rpm's.
Stev
January 15, 2018, 19:23:41 pm »
Hi,
he told me that the crank on their website is allready the light weight version.
http://www.scatvw.com/crankshafts/billet-flange/
- udo, i dont want to rev that high. RPM limiter something around 6,5k
you guys make my decision as easy as possible.
January 15, 2018, 20:50:18 pm »
Quote from: leec on January 15, 2018, 14:59:06 pm
Hi Udo,
Steven
Hi Steven,
. 8-86-4444F-3 Part Nummer for super light . They also drill the center , I ordered mine only drilled on the rod journals
January 16, 2018, 11:35:50 am »
[ Attachment: You are not allowed to view attachments ] Here you can see the strong design from scat
January 16, 2018, 18:52:21 pm »
Hi Udo, is that crank the same part number you mentioned?
January 17, 2018, 07:27:37 am »
Yes, but 78 stroke on this one . The part number was 86
January 17, 2018, 14:35:51 pm »
Thank you Udo
Stev
January 17, 2018, 21:03:34 pm »
anybody who knows hoch much lighter the crank is? Whats the additional price?
