September 23, 2026, 09:19:38 am
| |-+  Wanted
| | |-+  Shops in Norway
Author Topic: Shops in Norway  (Read 9268 times)
BC the Striper
« on: August 14, 2006, 16:41:58 pm »
Hi! I'm in a desperate need for a distributor cap + distributor rotor for a standard 1200 engine to my Mexico. Could you maybe give me some hints on where to find a shop in Oslo which will have these, or an online shop? I can't stand buses already, although it was the first day I had to use them!!!! Wink
Thanks in advance!
edit: I've checked with Biltema and they have distributor caps for golfs and jettas (at least that's what is listed on-line) and stuff like this:
"Kjøper du et komplett sett tenningsdeler, kan du skifte alt på en gang og slippe tenningsproblemeer i lang tid framover. Vil du vente med å skifte noen deler, gjør du også en god handel. Tenningssettene inneholder stifter, kondensator, rotor, fordelerlokk" - they say this is for 1302S and 1303S - what is the difference and will it run well on my engine, if there is no other option?
« Last Edit: August 14, 2006, 17:12:00 pm by kfiatek » Logged
« Reply #1 on: August 14, 2006, 20:30:38 pm »
Hi,
Im not sure the ignition parts from Biltema will work, but I guess they will.
Otherwise you could call Unneberg-bil at 33330606, they can help you.
Good Luck, let me know if you have further problems.
BC the Striper
« Reply #2 on: August 17, 2006, 16:56:13 pm »
got the parts from Biltema, installed them and everything works perfectly fine Smiley Therefore, I am back on the road again!
