September 26, 2026, 10:52:06 am
JPM MS 230 heads SOLD!!!!
Topic: JPM MS 230 heads SOLD!!!! (Read 6636 times)
Kari
January 19, 2018, 20:14:52 pm »
Cylinder heads JMP MS230 101.6 mm, WBX PCD, Valves Scat stainless steel48mm x 38mm, combustion chamber 39cc, 5 bolt Rocker Shaft , Logmech Valve springs HD, double , Valve spring retainers HD in chromoly and JPM King Cover Cast Alu Valve Covers. Heads are ported.
Price 2800e + shipping New price 2200e + shipping
SOLD!!!
Last Edit: February 04, 2018, 15:16:12 pm by Kari
Kari
Re: JPM MS 230 heads
January 19, 2018, 20:28:54 pm »
Last Edit: February 04, 2018, 15:16:29 pm by Kari
spoolin70
January 23, 2018, 07:54:54 am »
Hi Kari
Can I ask, where did you get the rocker shafts and blocks from to suit Pauter rocker arms ?
Good luck
Darren
Kari
January 23, 2018, 13:59:48 pm »
Quote from: spoolin70 on January 23, 2018, 07:54:54 am
Hi Kari
Good luck
Darren
It is one of kind, home made
Tomi
January 23, 2018, 16:04:32 pm »
Quote from: Kari on January 23, 2018, 13:59:48 pm
Well, actually it is not. We had 7 sets made and they are all gone but still have material for new ones. Probably not worth it though as they will be quite expensive.
Kari
January 24, 2018, 12:09:54 pm »
Quote from: Tomi on January 23, 2018, 16:04:32 pm
Thanks Tomi, so I have wrong information.
Kari
January 24, 2018, 12:11:02 pm »
up
Last Edit: February 02, 2018, 23:29:05 pm by Kari
spoolin70
January 24, 2018, 15:35:13 pm »
PM sent to you Tomi
Kari
February 02, 2018, 23:29:23 pm »
