October 28, 2026, 16:37:57 pm
352330 Posts in 28962 Topics by 6929 Members
Latest Member: Hanibal1
| | |-+  My 1966 Cal Looker project part #2
Pages: 1 ... 4 5 [6] 7 Print
Author Topic: My 1966 Cal Looker project part #2  (Read 165593 times)
Frenchy Dehoux
« Reply #150 on: April 26, 2019, 06:34:13 am »
  Few more shots !!
   Frenchy
Doctor Detail ( Retired )
Frenchy Dehoux
« Reply #151 on: May 03, 2019, 05:00:56 am »
   I installed my gauges yesterday and now the wiring will be next which is the easy part.
   Frenchy
Frenchy Dehoux
« Reply #152 on: May 03, 2019, 05:03:36 am »
   Two more shots !!
  Frenchy
Frenchy Dehoux
« Reply #153 on: May 17, 2019, 06:06:01 am »
   All is done on the 66 except for the headers to be modified because it is hitting on the apron and will burn the paint if I do not change this. My son told me to cut the welds off the flange and he will add a V band to make it right.
   Frenchy
Frenchy Dehoux
« Reply #154 on: May 17, 2019, 06:08:22 am »
  A few more pictures showing the fabricating pieces needed . When done should look like the one in the picture .
   Frenchy
Frenchy Dehoux
« Reply #155 on: May 29, 2019, 08:32:54 am »
  This is the last thing to do on the 66 for the completion of this project until the next one. The exhaust system took a while to get it done right.
   Frenchy
Frenchy Dehoux
« Reply #156 on: May 29, 2019, 08:35:19 am »
   Few more pictures
   Frenchy
Frenchy Dehoux
« Reply #157 on: May 29, 2019, 08:37:11 am »
   Few more
   Frenchy
Frenchy Dehoux
« Reply #158 on: May 29, 2019, 08:38:47 am »
   Last pictures !!
   Frenchy
Fasteddie63
« Reply #159 on: May 30, 2019, 03:59:28 am »
Badass,can't wait to see it
Frenchy Dehoux
« Reply #160 on: June 11, 2019, 16:54:23 pm »
   Well after a few years on working on this Cal Looker we made it to the Garden Grove Main street Show and also to the Bug In 44 in Fontana Motor Speedway !!
   Frenchy
Frenchy Dehoux
« Reply #161 on: June 11, 2019, 16:56:31 pm »
   A few more shots !
   Frenchy
« Reply #162 on: June 11, 2019, 19:29:15 pm »
Very nice! And congratulations for all that work. So, what's next ?  Wink
Frenchy Dehoux
« Reply #163 on: June 12, 2019, 07:42:52 am »
    Next will be my 1966 Ghia to do the same one I had back in 1976 and also my Belly Tanker with mid engine !!
    Frenchy
Eddie DVK
« Reply #164 on: June 12, 2019, 08:47:16 am »
Frenchy,
Are you going to make a remake of your yellow ghia??
That is in my opion the best looking ghia.
Regards Edgar
Frenchy Dehoux
« Reply #165 on: June 13, 2019, 06:09:49 am »
    Edgar Thank You for the kind words Yes my plan is to duplicate my 67 Yellow Ghia I had back in the mid 70's
   Frenchy
volkskris
« Reply #166 on: June 13, 2019, 07:16:55 am »
   Frenchy
I'm looking forward to that!
Great work on this car btw  Smiley
wolfswest
« Reply #167 on: June 13, 2019, 09:25:32 am »
Another great result!  Shocked
Whatever happened with your old KG Frenchy?  Sold to Japan?
Dem
« Reply #168 on: June 13, 2019, 19:50:52 pm »
    Frenchy
You never stop!
Again, wonderful car.
Frenchy Dehoux
« Reply #169 on: June 15, 2019, 14:59:26 pm »
   Dem yes the car went to Japan in 1984 I have tried to locate it but no luck with all the VW events they have there I figured I would see it somehow .
 Frenchy
Doktor
« Reply #170 on: June 15, 2019, 19:43:51 pm »
Nice cal-looker, great work (again).  Cool
dr.aircooled
wolfswest
« Reply #171 on: June 17, 2019, 09:42:51 am »
 Frenchy
that's a bummer...Was it sold to a collector?  But I will bet that the "replica" will even look better then the original!  Looking forward to it.
Matty c
« Reply #172 on: June 17, 2019, 14:31:51 pm »
Very nice frenchy look forward to seeing your ghia as I loved the original, have you managed to find some Herculon for the interior?
67heaven
Frenchy Dehoux
« Reply #173 on: June 17, 2019, 15:53:18 pm »
  The motor is already done and the front beam and the trans as well. I have the Porsche Alloys 14x6 I had polish so time ago. I just need to pull the body off the pan and repair the pan half .
  Frenchy
Frenchy Dehoux
« Reply #174 on: July 20, 2019, 07:29:12 am »
   I am looking to install a magneto on my motor which is a Hunt . Possibly having it polished first before I install it. And I will have the support bracket done in Blue which will go better with the color of the car .
   Frenchy
Frenchy Dehoux
« Reply #175 on: August 01, 2019, 05:26:22 am »
   Magneto for the 66 just a little polishing and here you have it. New cap and tag as well .
   Frenchy
RichardinNZ
« Reply #176 on: August 01, 2019, 09:07:02 am »
Nice.  I'd like to run one of those on my dual carb 36hp.
Sent from my CLT-L09 using Tapatalk
'58 Bug; NZ assembled
Dual Carb 36hp
« Reply #177 on: August 01, 2019, 09:39:30 am »
I ran a Vertex on the Okrasa engine in my '51 Split-window. Looked and worked great!
RichardinNZ
« Reply #178 on: August 01, 2019, 09:42:49 am »
I'm sure someone must have one in their shed somewhere down here.  I'll just need to keep my ear to the ground!
Dual Carb 36hp
Frenchy Dehoux
« Reply #179 on: August 02, 2019, 14:51:26 pm »
   Check on the Samba for Magnetos .
   Frenchy
