September 22, 2026, 21:02:03 pm
| |-+  For sale!
| | |-+  Race kit and other stuff
Author Topic: Race kit and other stuff  (Read 3428 times)
PiL
« on: February 05, 2018, 13:49:40 pm »
I have some kit that is now surplus to requirements so I'll be posting it as I am able to get descriptions organised.
First up is a race prepared swing axle gearbox. It's a strong 'box and I understand was originally put together by JMR. When I got it I went through it and freshened it up, and since then it has only done 2 installation passes.
It was used with a large capacity, normally aspirated engine. There are ratio's stamped on the casing as shown although I didn't confirm that is what is inside when I had it apart. It contains an aluminium spool which has been confirmed by me.
It has a heavy duty side plate and the case has been gusseted. When I got it there was a small hole in the bell housing which I filled to prevent anything unwanted getting inside. It looked like the case had perhaps been clearance a little too much at some point. I can vouch that the hole didn't have any effect on the operation of the gearbox.
I'm looking for £600 and it's located in the UK near Witney, Oxfordshire so can be collected from there (or if collected during working hours could be collected from Daventry).
Pictures available if needed (I would post them here but don't have a picture hosting account)
Cheers  Smiley
Check out the build of my new race car at:
http://pilsvw.blogspot.com/
WPS
« Reply #1 on: February 05, 2018, 14:23:49 pm »
You have pm
   WolfsburgPerformance.co.uk
      Instagram:  wpsengines
             07880-311850.
« Reply #2 on: February 05, 2018, 15:03:51 pm »
What else do you have for sale?
Lee
PiL
« Reply #3 on: February 05, 2018, 18:27:53 pm »
Gearbox now sold to Ian.
Leec, will be in touch by e mail ASAP.
Thanks Paul
