September 23, 2026, 03:46:04 am
| |-+  For sale!
| | |-+  Racecar For sale !
Author Topic: Racecar For sale !  (Read 4758 times)
vwfreak
« on: February 07, 2018, 09:27:52 am »
Beetle located in south of Sweden  ( Helsingborg ) , close to Denmark or Germany
Race / Street Beetle
 Maximum weight relieved , plastic screens around and glassfibre hood front and fenders.
rollcage  with reinforcements down to the rear plate at the engine.
 Lineloc
 The car is completely rustfree.
 Removable fenders and intermediate plate rear.
 The wing is easy to unscrew if you want.
 Dropped spindles with disc brakes inn front.
 Rims on picture not included! Stands on 4-plated steel rims.
 Rear seat is replaced with aluminum
 Reinforced in the back
 Everything in the car is well made and tested on the strip.
Gearbox that can handle 450-500hp
 aluminum spool
libertyrings
1  7.79
2 2.24
3 1.57
4 1.19
3.88
Engine: 2332cc Type 1:
• Okrasa 84 mm crank
• 94 mm cylinders
• Porsche con rods
• Super Flo heads, ported, with 48X38 valves
• Autocraft 1.4: 1 needle bearing rocker arms
• Engle FK10 camshaft
• MSD 6AL two step module, MSD timing control, MSD coil,
• NOS fogger + 100hp nitrous system
• 2 "Gene Mountain exhaust with stinger
 The carburettors on the picture are not included in the deal
 Fuelcell rci
 New lightweight plastic chairs (2pcs) with black cover
 Holley Red Electric Fuel Pump
 Reinforced drive axles
 M & H frontrunners will included if you want (start getting some minor drycracks)
Transport within a 20mil radius from Helsingborg is included, further away can be discuss.
 To Denmark is also good if you pay the ferry ticket 😉.
Gearbox 3100 euro
Car 1900 euro
Engine incl. Nitrous oxide (without carburettor) 2900
Drive Shafts 195 euro
Chairs 290 euro
Fuelcell 100 euro
If you sum up then it's parts worth over 8485 euro
 But if you buy everything, the price is as stated in the ad 7200 euro
 detailed images are available and uploaded or sent.
 I can be reached at  info@caltexmacken.se
 Or call +46708839896
/Tobias Bager
« Last Edit: February 08, 2018, 10:53:50 am by vwfreak » Logged
vwfreak
« Reply #1 on: February 07, 2018, 10:34:18 am »
« Last Edit: February 07, 2018, 13:51:00 pm by vwfreak » Logged
vwfreak
« Reply #2 on: February 07, 2018, 10:35:39 am »
« Last Edit: February 07, 2018, 13:51:19 pm by vwfreak » Logged
vwfreak
« Reply #3 on: February 07, 2018, 10:37:35 am »
« Last Edit: February 07, 2018, 13:51:30 pm by vwfreak » Logged
Morgan
« Reply #4 on: March 07, 2018, 06:55:17 am »
Hi,
Still available?
