November 02, 2026, 06:19:20 am
Latest Member: thunder_bac
| | |-+  Autometer Tach with a ECU?
Author Topic: Autometer Tach with a ECU?  (Read 6778 times)
UltraOrange67-2443
« on: March 03, 2018, 22:46:26 pm »
Anyone running a standard ignition Autometer Tach with a ECU?
Did you need the 9117 Adapter?
Cheers, Nick
1967 1200 2920cc EFI
spoolin70
« Reply #1 on: March 04, 2018, 10:15:42 am »
Hi Nick
My old engine used a MSD 6btm and distributor and when I changed over to DTA,  I think the Autometer was just connected to the tacho ECU output. We certainly didn't use the adaptor you mention.
My new engine will be using a Omex 710 and I plan to connect  the same Autometer to the ECU output again - providing I can resist the urge to get a digital dash of course  Wink
Surely your ECU has an output connection for tachometer ?
Regards
Darren
UltraOrange67-2443
« Reply #2 on: March 04, 2018, 19:22:15 pm »
Hi Darren
Yes my Omex 600 has a tach output, just wanted to check with other people.
Cheers, Nick
UltraOrange67-2443
« Reply #3 on: March 06, 2018, 22:02:04 pm »
Found out that Omex make a Tach driver for £18.
My mate has a LS V8 and is having trouble with his Autometer tach and he has found out they need to be set on 4 Cylinder setting to work.
spoolin70
« Reply #4 on: March 08, 2018, 07:55:21 am »
A lot cheaper than the Autometer version - https://www.autometer.com/tach-adapter.html
$104.95  Shocked
Sounds like a might need a driver too then, thanks for the info Nick.
I presume your using wasted spark or separate coils then ?
UltraOrange67-2443
« Reply #5 on: March 14, 2018, 22:16:13 pm »
I'm using wasted spark MSD Ford type coil pack.
