November 02, 2026, 07:33:21 am
Latest Member: thunder_bac
| | |-+  Disaster! Broken Alum case at oil pressure sensor. Help please!?
Author Topic: Disaster! Broken Alum case at oil pressure sensor. Help please!?  (Read 6665 times)
Richierich56
« on: March 04, 2018, 01:01:02 am »
Ive had a disaster with my new CB Aluminium case. Took plugs, oil pressure switch etc out to crank for oil pressure. On putting oil pressure switch back in and whilst tightening it, this happened:
The switch wasnt cross threaded or overtightened or anything - i guess it must just have been a weak area in the casting or something.
Does anyone have any advice on how i can sort this? Preferably without having to pull the motor.
Thanks in advance fellas
Rich
neil68
« Reply #1 on: March 04, 2018, 01:48:06 am »
I’ve used JB Weld on a similar broken gearbox fitting and it’s held for over 5 years with no leaks.
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
Richierich56
« Reply #2 on: March 04, 2018, 03:26:33 am »
How did you do it Neil? Will the fact this is the pressure switch make a difference?
UltraOrange67-2443
« Reply #3 on: March 04, 2018, 19:24:53 pm »
I drilled it out and added a larger fitting and screwed a pressure sending into the fitting.
1967 1200 2920cc EFI
Sam K
« Reply #4 on: March 26, 2018, 20:38:22 pm »
That happened to me a couple years ago on a aluminum case and the sender wasn't that tight. I had a friend weld it up and I drilled and tapped it and put in a time sert.
Richierich56
« Reply #5 on: March 29, 2018, 10:37:44 am »
All sorted now chaps - a friend stepped in and helped me out big time. Tha ks for the advice.
spoolin70
« Reply #6 on: March 29, 2018, 12:07:28 pm »
Which method did you use for the fix then ?
Please share  Wink
