September 23, 2026, 04:48:15 am
| |-+  Technical stuff
| | |-+  Fuel regulator problem
Author Topic: Fuel regulator problem  (Read 5236 times)
big d chop
O/FF 16
« on: April 29, 2018, 12:18:07 pm »
I’m using a Holley blue fuel pump and a Holley fuel regulator on my 2165 N/A engine but for some reason my regulator won’t adjust down it staying between 13 & 15, I’ve tried another new Holley regulator but have the same issue.
What regulator are people using or any suggestions what it could be.
Darren
OFF 16
hotstreetvw
« Reply #1 on: April 30, 2018, 21:24:39 pm »
I think the regulator from the red pump is what you need.  The blue pump works, but the regulator range is too high for IDAs.  The regulator with the blue pump is 4-1/2 to 9 psi.  The regulator with the red pump is 1-4 psi.  Make sure you pull the rubber plug on your pressure gauge (if its liquid filled), that will calibrate it to your altitude.
All that said I'm not a fan of the dead head regulator.  I had already run a second fuel line, so I switched to the aeromotive X1, which is a return style regulator.  It can be used low pressure for carb applications, or the guys can be swapped out and run at high pressure for fuel injection.
Will
« Reply #2 on: May 01, 2018, 07:49:01 am »
Holley Red regulator is fine - used them for years and years with IDAs. Easy to install, easy to adjust and easy to rebuild if necessary.
big d chop
O/FF 16
« Reply #3 on: May 01, 2018, 12:35:19 pm »
Cheers  ,I've ordered one know
OFF 16
AZOfftheWall
« Reply #4 on: May 01, 2018, 16:36:02 pm »
You can buy the red spring from Holley to lower the pressure of the regulator you have, rebuild kits come with both springs.
