November 02, 2026, 08:14:10 am
Technical stuff
ZF LSD swing axel question
Topic: ZF LSD swing axel question (Read 20428 times)
May 27, 2018, 10:08:16 am »
Ok bought a ZF LSD (swing axel) which looks nice on the outside, but is there a way of testing if it is ok to use.
I saw that there are new lsd plates for IRS ZF available (on the samba Bruce T), but don t see this for swing axel ZF s.
Need help.
Thanks in advance
Re: ZF LSD swing axel question
July 06, 2018, 08:37:25 am »
VW showed measuring the break-away torque. Get the busted spade of an axle from a drag racer, weld a socket to it and install with fulcrums. Lubrication will affect the readings greatly.
Take it apart? Beware, the number one cause of swing axle ZF failures is due to the dummy that previously assembled it wrong.
Can you post the 10 digit ZF part number engraved in the housing? Starts with 4061 00x xxx
Felix/DFL
July 06, 2018, 20:59:31 pm »
Congrats, a ZF LSD for swing axle is a rare part nowadays.
You will really see how it's condition is when you see the state of discs...
For a start check technical bulletin 2/1968:
https://www.thesamba.com/vw/archives/manuals/techbulletins/h1.php
A good read, print out and study before loosening any screw!
Post some pic's here, and listen to bruce
repeat listen to bruce...
Best greetings, Felix
July 07, 2018, 11:44:19 am »
Quote from: Bruce on July 06, 2018, 08:37:25 am
I will make some pictures sunday, and post it here.
Quote from: Felix/DFL on July 06, 2018, 20:59:31 pm
That was my plan.
Oooooh already made some pictures... I forgot... number is not complete visible.
Last Edit: July 07, 2018, 13:02:10 pm by Eddie
pupjoint
July 08, 2018, 05:51:33 am »
mine
pupjoint
July 08, 2018, 05:54:41 am »
was going through the bulletin, in order the adjust the ring gear with the VW297, it says i have to disaasemble the LSD, get the admustments done, reassemble the LSD .
anyone here does that as i am a bit worried about opening the diff, in case i break something and cannot get replacement parts.
if i dont use the VW297, it is a lot more work? any ideas?
July 08, 2018, 23:11:09 pm »
Mine does not have a number on top like the picture above.
It has an engraved number on the side.
I could not get the number in one picture, but the number is 4061 001 014/L140 786
There are numbers on bottom en top, but those don t start with 4061 …
Hope this usefull
Edit: the other numbers are 301070 and 301069 (or 301089?) Left of the numbers is a kind of marking I can not read..
Last Edit: July 09, 2018, 21:17:56 pm by Eddie
brewsy
July 09, 2018, 21:42:53 pm »
Interesting.
By the looks of the ramps it looks like its a two way locker.
Id have expected a 'stock' unit to be one or at least 1.5 way
Marc
July 10, 2018, 07:31:36 am »
Quote from: brewsy on July 09, 2018, 21:42:53 pm
Interesting.
Marc
I am new on this topic so, how can you see if it is a 1.5 or 2 way lock..
Is it in the number?
July 10, 2018, 07:33:19 am »
What are you talking about?
July 10, 2018, 07:48:35 am »
Quote from: Eddie on July 08, 2018, 23:11:09 pm
The ZF part number of your diff is 4061 001 014. This means it has bi-metallic discs with the 4 extra shear pins, and it's for 8 bolt ring gears as you can clearly count. This is the most common version of swing axle ZF.
The L140786 is your diff's serial number.
The other stamped numbers are just the meaningless part numbers of the housing. Since all ZF diff's part numbers start with 4061, they didn't bother to stamp those into the housing parts. Otherwise their full number would be 4061 301 070, etc.
Wallace's diff is an older diff that was originally made for 6 bolt ring gears, then later drilled for 8 bolts. Those diffs use the same technology bi-metallic discs, but without the 4 extra shear pins. Your diff's part number will likely be 4061 001 006.
If you plan to take it apart, please wait for instructions. If you don't, I guarantee you will destroy the bolts. GUARANTEED!!! In the past I have ruined many bolts. Now I can get every one of them out without damage.
Have you found an axle spade to make a tool?
July 10, 2018, 08:13:33 am »
Quote from: Bruce on July 10, 2018, 07:48:35 am
Thank you Bruce.
Have a spade, but did not test the lsd yet. Will test it, before I will open it..
And if I will open it, I am sure to not do anything without asking you first.
If you don t mind.
brewsy
July 10, 2018, 09:10:29 am »
Bruce and Edgar,
Look here:
http://www.intothered.dk/simracing/differential.html
Under the 'impact on handling' section.
The style and shape of the ramps dictate whether the locking works under acceleration or deceleration and can directly influence the handling of a car.
For something like a T1 which is renowned for snap oversteeer if power is removed mid corner (lift off the throttle) Im very surprised its not setup to be a 1 way.
However this guide seems to indicate the opposite of what Ive read on the subject so far. Any reps from Salisbury or ZF around to explain further??
Cheers,
Marc
Quote from: Bruce on July 10, 2018, 07:33:19 am
July 10, 2018, 10:08:33 am »
Ooooh ok.
I know now what you mean, but a ZF LSD works on acceleration and deceleration.
brewsy
July 10, 2018, 11:10:07 am »
Yup,
According to that person it seems like a 45:45 setting.
Quote from: Eddie on July 10, 2018, 10:08:33 am
Ooooh ok.
August 10, 2018, 10:33:37 am »
Ok have found a extra axle to test the LSD.
But have a question I don t really understand how to test it..
I saw the samba manual... but not that does not help me further.
I understand you have to turn it with torque, but do I block the other end of the LSD than or what.
Thanks in regard.
Mats Herrlander
August 18, 2018, 18:31:09 pm »
No.
Just simply put the diff. in a vice and measure the brake away torque (with a torque wrench).
August 19, 2018, 10:03:35 am »
Ok that part I get, but i think my english is not that good.
So what does brake away torque mean, the force that is needed to turn the diff, or the force that is needed to block the diff?
Thanks in advance.
Mats Herrlander
August 21, 2018, 10:36:10 am »
You want to measure the torque needed to overcome the friction of the discs.
If you do the same procedure with a standard diff. you get zero torque.
Buckel up the diffrential in a vice, insert the spade into one end of diff., turn the torque wrench (and change torque), untill "you find the click". Now you found the torque value. Should read around 3 kpm / 30 Nm, but can read 2, 5, 9 ... what ever, depending how well stored and maintained the diff. has been.
August 21, 2018, 13:37:32 pm »
Quote from: Mats Herrlander on August 21, 2018, 10:36:10 am
Thank you,
I think I got it now.
October 13, 2018, 08:33:50 am »
Ok have tested the diff, it starts to 'click' at 25 NM, is this ok?
Or is this to low?
Last Edit: October 13, 2018, 08:36:43 am by Eddie
October 18, 2018, 08:25:56 am »
I'd say it's good.
When you're turning it, is it smooth, or jerky?
October 18, 2018, 09:11:17 am »
Hi Bruce,
When turning it, it is smooth..
Would you recommend opening it or leave at is.
Thanks for replying, much appreciated.
