September 23, 2026, 14:44:29 pm
| |-+  Technical stuff
| | |-+  Spark plugs fouling in 1915 - have tried everything....
Author Topic: Spark plugs fouling in 1915 - have tried everything....  (Read 27841 times)
Speed-demon
« on: June 04, 2018, 07:38:54 am »
Hi
I have a 1915 With this setup: Engle 110, Stock rockers, 10:1 compression ratio, pertronix ignition. The heads are CB 044 with 40 and 35 mm valves, ported.
The engine is run in JeeRacing's dyno, and ran well. As far as I remember it dynoed approx 130 hp without belt with a merged header.
The problem is that the spark plugs on one side is fouling after a couple of hour oof driving in normal traffic. The carbs are chinese IDF 48 with 36mm venturis. 55 idle jets and 125 main jets. The spark plugs are NGK B6ES. The carb float height is spot on, (and triple checked). The needle vaves are checked (and working).
Any ideas? I have tried another ignition system (009 + Bosch coil) without success. I have run through the carbs several times. I have run out of ideas.....
BR
Jens Kristian
« Reply #1 on: June 04, 2018, 09:51:57 am »
Have you tried to swap the carbs over to see if the fouling changes sides?
Speed-demon
« Reply #2 on: June 04, 2018, 11:02:00 am »
No. The engine is in a bus, and it is very difficult to swap carbs. By the way, the carbs are responding as normal to adjustments in the idle screws.
« Last Edit: June 04, 2018, 11:04:50 am by Speed-demon » Logged
DWL_Puavo
« Reply #3 on: June 04, 2018, 12:06:51 pm »
Do you know your fuel pressure? Pressure adjuster is at least quite easy bolt-on -thing to try.
Other thing that comes to mind is the temperature of the fuel on carb bowl that could cause problems - but that usually manifests as poor start after running hot for a while.
If the carbs themselves are hard to change - you seem to have taken the carb tops off for float and needle valves check. If the problem is still somehow related to needle valves or floats, could you try to swap only carb lids?
Speed-demon
« Reply #4 on: June 04, 2018, 12:12:53 pm »
Fuel pressure is controlled by Filter King fuel pressure regulator. http://espimages.biz/2386/I/179/52/FPR004.JPG It is supposed to have a factory setting of 3 psi, which should be OK. I'm using a standard type mechanical fuel pump. I have not tried to swap carb lids.
« Reply #5 on: June 04, 2018, 17:57:19 pm »
Take a pic of your plugs so we can take a look.
Have you tried a hotter plug as a test? Smaller numbers are hotter with NGK so try a 5 and see what happens.
Also, your plugs are standard type and not BP, with the P standing for projected electrode.
Projected electrodes are better for resisting fouling.  Wink
Speed-demon
« Reply #6 on: June 04, 2018, 21:38:19 pm »
I went from spark plug 8 (which was clealy too cold) to spark plug 6. Did not help. Can try BP4ES and see what happens...
« Reply #7 on: June 04, 2018, 21:42:15 pm »
Sure. When you pull the plugs try to get a pic of the fouled ones vs. the good ones on the other side. That would be interesting to see.
Andy
« Reply #8 on: June 04, 2018, 22:27:32 pm »
Do the Chinese Idf copies have the choke circuits, sometimes extra fuel can leak through them on Webers, plugging the  choke circuits would stop any potential route for excess fuel.
Speed-demon
« Reply #9 on: June 05, 2018, 07:39:31 am »
How can I plug the choke circuits?
Andy
« Reply #10 on: June 05, 2018, 08:38:01 am »
There are several ways to plug the circuit
Tap a thread and use a screw to firmly hold the moving parts of the choke mechanism closed.
Tap and use a plug to block the gallery.
Use JB Weld to block the gallery. I did this , it works fine but I am not sure how long JB Weld stands up to fuel.
Also if you don't already have them , fit heat insulating spacers under the carbs, IDF's can spill fuel caused by heat soak after shutdown , this can result in a carb fire.
« Reply #11 on: June 05, 2018, 08:56:21 am »
What is the lambda telling you while driving in the "fouling" range?
-BB-
Brown-nose
« Reply #12 on: June 05, 2018, 08:57:45 am »
I have Empi 44s. They eliminated the choke circuits on these, I imagine your Chinese 48s are the same.
Speed-demon
« Reply #13 on: June 05, 2018, 09:28:47 am »
-BB-
The lambda is a bit rich. But it is a Vintage Speed exhaust, With a strange placement of the lambda, so I do not trust it too much.
« Reply #14 on: June 06, 2018, 07:26:58 am »
-BB-
What is a bit rich if I may ask? I tuned my 1915 with Vintage Speed exhaust perfectly well with 48 IDF`s, lambda and IR temp. Is it enough air entering the engine compartment on the side that is fouling? And does anything change when/if you have the engine lid open? And if you use a IR temp meter, is there any major difference in the exhaust temperature from side to the other side? If you do not have a IR meter you can borrow mine or bring the bus to the garage.
How cool would it not be with asymmetrical jetting  Smiley
-BB
Greg Ward
« Reply #15 on: June 06, 2018, 07:46:18 am »
Wow, was that a typo or do you really have 125 main jets?
The 44IDF comes stock with 135 mains and the 48IDF with 150 mains.
Having run both on my 1915 engines of different combinations, I always ended up at a jet size over, so 140 if it was a 44IDF and 155 if a 48IDF.
44IDF's come standard with 36mm vents and the 48IDF come standard with 40mm vents.
If you are running a 48IDF with 36mm vents and 125mains it has to be way too lean.
Greg
Speed-demon
« Reply #16 on: June 06, 2018, 11:36:31 am »
Greg
Hi
I have tried 40 and 36 vents in the IDF 48s
Ran 145 main jets With 40 vents (on the dyno) and 125 main jets with 36 vents (used lambda in the car). Anyway, I do not think that too small main jets cause the fouling problem.......
BR
JK
alex d
« Reply #17 on: June 06, 2018, 12:28:41 pm »
have you measured what's your actual fuel pressure?
« Reply #18 on: June 06, 2018, 17:39:24 pm »
Hi
BR
Jens Kristian
1. measure voltage @ 1.5 terminal of your coil with key on. You might find it's 10V or less. Before I went to CD ignition in my car in 1994, I wired up a Hella 40amp relay so the coil was getting full, clean 12V.
2. try NGK iridium plugs, I believe you can get your configuration and heat range in iridium, the part number will end in -"EIX". Be careful about going to a hotter plug. If you aren't fixing the issue, but masking it, by going to a hotter plug, if what ever the root cause is someday fixed, you're going to have an issue you won't want.
3. check valve lash
4. I don't think it's a fueling issue. If it was, you'd be having tuning issues more often than just after hours of being stuck in traffic. Excess fuel pressure makes a Weber car an absolute nightmare to drive at steady state. I mean pure misery. The car will hunt and bumble along until you ring its neck and stand on the gas. If it runs good otherwise, except under conditions you described, I think it's an ignition / voltage issue. I'd even measure voltage @ 1.5 on  coil AFTER driving it in traffic and it begins to act up.
Good luck
Jim R.
« Reply #19 on: June 06, 2018, 17:44:17 pm »
Hi
BR
Jens Kristian
3. check valve lash
Good luck
Jim R.
Sorry- one more thing. Air filter(s)- clean, correct dimensions, able to pull air in..? Velocity stacks aren't too tall, and jammed up against air filter lid? good luck
« Reply #20 on: June 06, 2018, 19:39:28 pm »
I normally run 5's in stock engines (factory original) and 6 for higher compression engines like my 9.5:1 1776. I have 7's in the turbo.
« Reply #21 on: June 06, 2018, 23:13:25 pm »
chinese carbs eh  Roll Eyes
Speed-demon
« Reply #22 on: June 07, 2018, 08:45:45 am »
Hi
BR
Jens Kristian
3. check valve lash
Good luck
Jim R.
Thanks for the help.
Valve lash is checked. I am beginning to believe that it is not purely engine related. It might be that the engine does not get enough air. The car it sits in only have "rib air intake" on one side. The fouling happens on the other side. The fouling happens after long drives at cruise speed. The enging compatment get hot as a result of limited air intake and the vintage speed exhaust. On Shorter rides it goes like champ. It idles smoothly. It behaved nicely in the dyno. So it might be related to lack of air, or electical issues (too low voltage as you point out)
« Reply #23 on: June 07, 2018, 13:31:07 pm »
Take a longer drive without engine lid, or racket it up, so the engine gets all the air it needs.
After that, if the fouling is due to lack of air, maybe get some duckting from under the car to the engine bay?
PPRMicke
« Reply #24 on: June 07, 2018, 15:53:09 pm »
MAX 2.5 psi on idf (china 2.2 psi )
China needle valve is crap (buy Italy manufactured)
/// Micke
« Reply #25 on: June 07, 2018, 16:05:35 pm »
What type of fuel pressure gauge do you use to check pressure to the tenths of a pound? Mine is 0-15 I think and hard to read those low values. Undecided
Greg Ward
« Reply #26 on: June 08, 2018, 06:32:28 am »
No, I get you, I agree, I would think 125mains would be way too lean...
So can I ask what your Air correction jets are?
Cheers,
Greg
DWL_Puavo
« Reply #27 on: June 11, 2018, 15:57:38 pm »
Too small air inlet to the engine bay might indeed be the problem! It also could explain why your unusually small main jets compared to aux venturis still somehow work.
My older beetle had two of the air inlet louvers taped shut from under the outer grill by previous owner. Probably to save dual carbs from getting wet when left to the rain. My ET got whopping 0,6 sec better (to 15.2) on quarter mile just by removing engine lid - top rpm's were much better.
« Reply #28 on: June 11, 2018, 18:18:11 pm »
Cheers,
Greg
Would it if the engine doesn’t get any air?
« Reply #29 on: June 11, 2018, 19:12:25 pm »
Deck lid standoffs to the rescue!  Roll Eyes
