September 24, 2026, 04:21:19 am
| | |-+  Sensors for dta
Author Topic: Sensors for dta  (Read 6551 times)
Rocket Ron
It's old school for a reason
« on: June 18, 2018, 08:17:53 am »
The time has come to buy some sensors for my fuel injection set up. I was going for a speed shop crank trigger set up but they seem to be cutting down on their range so I was wondering if there are some generic sensors I can purchase on eBay or Such. I have purchased the loom through the speed shop but he needs some sensors to make it up for me. Was going to use the generic VAG coil pack but looking for recommendations for the rest.
Ecu is dta 40 and I’m going to be running twin Jenvey throttle bodies with possibly some NOS at a later date. Where did you get your sensors?   Cheers in advance
Regards Ron
13.12 @ 101.84
Grooving out on life
Erlend / bug66
Global Moderator
SCC Event
« Reply #1 on: June 18, 2018, 08:22:46 am »
Regards Ron
There is an easy route; open the DTA program on your computer and check which sensors are preset in the ECU. Almost all can be setup manually, and there is a few that DTA setup for you.
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
Rocket Ron
« Reply #2 on: June 18, 2018, 09:56:38 am »
Thanks will try that
13.12 @ 101.84
« Reply #3 on: June 18, 2018, 09:57:13 am »
Thought you were on holiday?!! Grin
Lee
« Reply #4 on: June 18, 2018, 11:19:49 am »
Ron I used crank trigger wheel & sensor set up from Dubshop on 67 which we stock now, have a couple different size trigger wheels in stock for different pulleys, you just need to swap the sensor plug on loom to match
Rocket Ron
« Reply #5 on: June 18, 2018, 12:07:35 pm »
Lee
Only so much sun bed time a man can take. !!! Bored shitless now to be honest and wishing I could have been at the pod on the weekend after seeing some
Photos
Richie
Sent you a pm
Ta Ron
13.12 @ 101.84
Rocket Ron
« Reply #6 on: August 06, 2018, 07:14:28 am »
Found this and thought I’d add to the post for info
13.12 @ 101.84
