September 23, 2026, 22:28:26 pm
Technical stuff
dishing mahle 94mm pistons
Topic: dishing mahle 94mm pistons (Read 6622 times)
JIMP
July 03, 2018, 17:35:14 pm »
I have a street engine, n.a. going to 1914cc from 1.6, , I have the 94mm mahles, std comp height (K70401), as I need cc to lower the compression, how deep can I cut a dish on the crown without being dangerous? Comp will be just below 9:1, I suggest a 70mm circle dish on the crown?, but how much deep would be OK?
Thanks in advance
Dimitrios
dragvw2180
Re: dishing mahle 94mm pistons
July 03, 2018, 18:20:56 pm »
A suggestion would be to add a copper head gasket like we use on turbo engines . They make them in different thicknesses .
Martin S.
July 03, 2018, 20:36:10 pm »
Why such low compression? I have 9.4:1 in a 1776 with stock 34pict and muffler, which runs great on regular crappy gas.
JIMP
July 04, 2018, 08:11:42 am »
Hello, thanks for inputs, i know that shims would be the easy option, but I just need to maintain something from that squish area, so I need to do it the harder way,
Martin I'm with you actually, you're right, but this specific one will go on a heavy car -bus T2- and the owner also has a heavy foot, so I\m thinking to give it some extra chances to survive!
anyway was thinking for a dish at 70mm x2mm depth, if just someone can verify that this is good or let us with a pretty thin crown, as I measure it the crown will end in like 3mm thick after dishing,
Friendly
Dimitrios
Martin S.
July 04, 2018, 15:41:18 pm »
I still wouldn't do it. Simply back off the timing until it doesn't ping for the gas you're using and it won't be a problem.
Regardless, my turbo needed a dish and I believe it was cut .070" (1.8mm) using AA slipper skirt (the cheap ones).
RaptorLou
July 04, 2018, 22:36:52 pm »
[ Attachment: You are not allowed to view attachments ] most pistons are made thicker on top to allow valve relief. Measure the thickness. These are 94 compression with hi wrist pin CP's
Back in the day I routinely took .100 off Mahle pistons. [ Attachment: You are not allowed to view attachments ]
Lou
Joel Mohr
July 04, 2018, 23:26:43 pm »
Hemi cut....
SEE YA AT THE RACES!!!
JIMP
July 05, 2018, 21:44:49 pm »
Ok thanks a lot for inputs and pics, I made finally a 2mm deep dish, I hope it holds and will not have problems, the compression came to 9,1:1, that's with an fk8, so I think it wont be a problem,
again thanks a lot for helping
Friendly
Dimitrios
