October 14, 2026, 10:20:05 am
| |-+  For sale!
| | |-+  Bears Rebuilt 091 with Rjes Bellhouse & First motion shaft & longer 3&4th gears.
Author Topic: Bears Rebuilt 091 with Rjes Bellhouse & First motion shaft & longer 3&4th gears.  (Read 2871 times)
Big Al
« on: July 04, 2018, 09:14:11 am »
I just bought this as a panic purchase yesterday thinking I could use parts to fix my own similar gearbox. Unfortunately after speaking to Bears this moring neither the nose or internals are compatible with my own as I have additional uprated Scat parts so back available for sale.
It's a Bears Motorsport rebuilt 091 box with new 1st and 2nd gears and longer 3rd and 4th suitable for a subaru. Never used on the road so as 'new'.
Also has a Rjes Bellhouse, clutch arms and slave bracket & Subaru spline first motion shaft meaning you can run a bigger stock subaru clutch as standard.
I believe it has a bus nose so will bolt right into a bus or you can get adaptors to fit in a bug.
Basicslly if your going subaru in your bus this is practically a bolt in setup ready to go, or adapt to a bug with linkage adaptor and T4 to T1 gearbox mounts (think these are about 80 quid, I have 2 out or 3 parts I can throw in somewhere you will just need a top strap which I used on mine).
A good 091 will set you back £700 quid, Internal parts were £1250, rjes bits £750 and built at Bears a highly recommended box builder.
Looking for a quick sale Or SWAP for professional paint job on my bug.
delete speaker deck account
