September 17, 2026, 07:57:39 am
Latest Member: Bad Habit
| | |-+  waterboxer case.
Author Topic: waterboxer case.  (Read 7985 times)
Bad bug
« on: July 07, 2018, 18:36:24 pm »
Good day All,
I am doing an oxyboxer engine for my bug and was wondering what is the largest crank that can be placed in a waterboxer case with chevy journals.
« Reply #1 on: July 07, 2018, 19:39:35 pm »
What crank are you going with?
They made 80 and 82mm WBX cranks. At least Oettinger made them.
bedjo78
« Reply #2 on: July 07, 2018, 19:43:44 pm »
I install 86 crank with fat alu rods. 88 with H rods will be in
Bad bug
« Reply #3 on: July 07, 2018, 23:09:26 pm »
I will be running a 80mm waterboxer crank in the engine with webcam 86b camshaft, latest version of the los panchitos head, 5.6 inch H beam rods, 9.6:1 compression ratio, 48mm dellorto trijet carbs (37 vents) and 1 5/8 exhaust system. I am planning to make 170HP with this engine.
Bad bug
« Reply #4 on: July 07, 2018, 23:11:11 pm »
Nice i am glad i got the case done. i have options latter to going big on the engine.
PPRMicke
« Reply #5 on: July 14, 2018, 20:29:00 pm »
4" pistons ?
170 hp ?
Why as little as 170
The blocks can handle more than 330 hp
/// Micke
« Reply #6 on: July 14, 2018, 20:49:26 pm »
.    I would build this with an original type1 case   Good for many years on the street
Bad bug
« Reply #7 on: July 14, 2018, 21:12:41 pm »
4" pistons ?
170 hp ?
/// Micke
I know what i initially wanted to do was build a 4" inch bore engine with the 80mm crank. The heads would have been the waterboxer head but the machinist wasn't keen on doing it so i went with this instead for the first build out. I know the case can take a lot of power skinne beetle has proved it.
Bad bug
« Reply #8 on: July 14, 2018, 21:16:18 pm »
Udo would love an 86mm crank in the case but at this point i understand that you can't stroke relieve a waterboxer crank beyond 80mm without issues
« Last Edit: July 14, 2018, 21:21:10 pm by Bad bug » Logged
Bad bug
« Reply #9 on: July 14, 2018, 21:26:07 pm »
Ok Udo i looked at your post again. The reason for not going with an original case is they are too expensive to build a stroker and they just aren't that strong. I wanted a strong case to build a strong engine no matter how hard i looked i kept coming back to the waterboxer case. I have two other engines to build for my beetle a t4 and a waterboxer that will be possibly a 2.6ltr the t4 will hopefully be 2.8ltr.
