November 02, 2026, 17:18:30 pm
15X6 ERCO WITH 4" BACK SPACING..WILL THEY FIT UNDER STOCK REAR FENDERS?
Topic: 15X6 ERCO WITH 4" BACK SPACING..WILL THEY FIT UNDER STOCK REAR FENDERS? (Read 11154 times)
Stephen schmidt
July 11, 2018, 00:52:06 am »
As the title states. I have 1 1/2" widened rear fenders, but it wold be great to run a stock width fender if possible.
The car isn't together yet so I haven't had time to mock it all up. Just curious if it will work!
Trans is a short axle with type3 5x130 drums.
Car: 1959 VW Beetle
Tires are M&H 26x15x6 Slicks.
Thanks!
neil68
Re: 15X6 ERCO WITH 4" BACK SPACING..WILL THEY FIT UNDER STOCK REAR FENDERS?
July 12, 2018, 05:54:19 am »
I have CMS 6” wheels (CMS produced the ERCO wheels). Mine are 3.5” backspace with short axles and with M&H 215/65 drag tires it fits just nicely under my stock 68 fenders. So you should be fine with 4” backspace.
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
Dynojet Test:
July 12, 2018, 09:30:22 am »
I have MH 215/65-15s with 5,5" ET30 wheels. Fits under stock fenders easy.
Same with 7" ET23 Porsche rims and 205/70 tires so I guess you are good to go on stock fenders.
Stephen schmidt
July 12, 2018, 17:57:35 pm »
Yah, I was thinking it would be fine! Most people run 15x6 with 3.5" pack spacing. So the tires would tuck in another 1/2" and the type 3 drums are a hair wider, so it might wash in the end.
Thanks guys!
Stephen
July 13, 2018, 07:30:50 am »
If you have adjustable springplates you could have clearance issues on the inside of the tyre. You could always run a small spacer to find tune the position of the wheel.
Stephen schmidt
July 23, 2018, 15:29:26 pm »
Quote from: Neil Davies on July 13, 2018, 07:30:50 am
I won't have adjustable spring plates, however a spacer may not be a bad idea! Thanks!
August 19, 2018, 10:41:50 am »
Quote from: Erlend / bug66 on July 12, 2018, 09:30:22 am
is this with short axles? i have IRS and it seems not possible with the ruff trialfitting i did a few weeks ago.
August 19, 2018, 20:22:00 pm »
Quote from: nicolas on August 19, 2018, 10:41:50 am
Short.
I’ve done it on long axles also.
August 20, 2018, 12:27:47 pm »
Quote from: Erlend / bug66 on August 19, 2018, 20:22:00 pm
Short.
oh, i wasn't able to do that on IRS… it does have type3 drums, but i need to look at it better. i want cookies to fit under the fenders. still puzzling.
August 20, 2018, 12:50:42 pm »
Long axles. I think the rears are 6 inches. 215/65-15 MH DOTs
August 21, 2018, 07:28:50 am »
yes they are.
i was putting the 7's on, but no chance. they are too wide on long axles or IRS. without narrowing. but thank you very very much.
August 21, 2018, 12:28:31 pm »
7s are too much on long axles.
