August 12, 2026, 12:47:56 pm
Project CFC#1, turbo, back halfed and light
5
Topic: Project CFC#1, turbo, back halfed and light (Read 136157 times)
Re: Project CFC#1, turbo, back halfed and light
Reply #60 on:
January 14, 2019, 19:44:32 pm »
Quote from: richie on January 14, 2019, 19:36:16 pm
Quote from: Erlend / bug66 on January 14, 2019, 08:51:24 am
But when the price jumped up almost 100% I really couldn't justify it.
Welcome to the world of
street
cars
Your comment just needed a slight adjustment..
Reply #61 on:
January 14, 2019, 21:19:08 pm »
Quote from: Erlend / bug66 on January 14, 2019, 19:44:32 pm
street
cars
Reply #62 on:
January 15, 2019, 09:11:20 am »
Our new garage is about halfway between Oslo and Gardermoen, so I thought I should drive the car to SCC the first year it'll race..
I think it's about 25km, so doable
Does anyone have a good tip about brakes? The car already have discs on all four corners, but 4x130 rotors. Money wise I should just buy new rotors in chevy PCD. 10,22 on EMPI brakes was no problem, so a second faster shouldn't be a big problem?
Reply #63 on:
February 02, 2019, 19:54:40 pm »
No car in the garage, so tore the engine for a checkup.
So far so good!
Reply #64 on:
February 02, 2019, 19:57:53 pm »
I can see a car in the garage
Hard to tell on plugs as looks like they done a few passes? but timing mark looks quite far down strap
Reply #65 on:
February 02, 2019, 20:10:08 pm »
Quote from: richie on February 02, 2019, 19:57:53 pm
Not my car
All last season. Dyno and SCC, and some street miles
Reply #66 on:
February 02, 2019, 20:11:37 pm »
How does one read timing on the plug?
Reply #67 on:
February 02, 2019, 20:32:23 pm »
On the ground strap, if you do a pass on new plugs and check them after[ mustnt drive car back though, shut it off straight after pass] you will see a ring on strap, around the bend area or slightly before seems to be ideal on alcohol based fuels
Reply #68 on:
February 02, 2019, 21:24:39 pm »
Quote from: richie on February 02, 2019, 20:32:23 pm
Ok, i believe I’ve got around 20° timing at 32-33 psi.
Reply #69 on:
February 02, 2019, 21:31:06 pm »
I’ve also spent some time to figure out the angles to mount the coil overs at.
At level axles (0° camber) they will be angled 20° inwards to the middle of the car, and 90° to the upper ladder bar tube.
This will aid the coil overs to not loose wheel rate (spring rate measured at the wheel).
If you mount them straight up, they will get a wrong angle due to the arching of the swingaxle, and get less and less wheel rate as the wheel travels up.
Now the wheel rate should get higher as the car squats more and more.
Reply #70 on:
February 02, 2019, 22:33:45 pm »
Hi,
Are the heads CB wedgeports?
What cc is in the chambers
Reply #71 on:
February 02, 2019, 23:06:41 pm »
Quote from: leec on February 02, 2019, 22:33:45 pm
Hi,
Yup, the new style.
67cc chambers, 1,2mm deck and 8,2-1 I think.
Haven’t touched the heads.
Reply #72 on:
February 02, 2019, 23:19:06 pm »
What barrels and pistons? Have you dished the pistons?
Reply #73 on:
February 02, 2019, 23:56:27 pm »
Quote from: leec on February 02, 2019, 23:19:06 pm
Wiseco and REVs.
No need for dishing pistons with big enough chambers
kalle155
Reply #74 on:
February 04, 2019, 12:26:12 pm »
Are you using only the stock dh oil cooler or do you have an extrenal also? , and does your oil temp stay cool with that?
Reply #75 on:
February 04, 2019, 12:45:16 pm »
Quote from: kalle155 on February 04, 2019, 12:26:12 pm
Stock and an Atoimic cooler also. I might skip the DH cooler. The engine will be 3" higher in the new car, and I think I'll need to be able to remove the shroud by just pivoting it out.
Oil temps are manageable
Reply #76 on:
February 08, 2019, 08:41:56 am »
Tore the rest of the engine last night, rod bearings are shite and mains may work again.
I'll change the oil pump as it finally got some nicks in it.
Reply #77 on:
February 08, 2019, 08:50:17 am »
Solution: Dry sump. Check out TP pump. Very good stuff.
CB is more affordable but needs massaging and has some questions marks.
Pauter, Autocraft are jewels but are probably overkill for most applications.
Some of my cars:
Reply #78 on:
February 08, 2019, 08:56:03 am »
Quote from: Frallan on February 08, 2019, 08:50:17 am
I've thought the same thought.. However I've never had any oil pressure problem.
I believe this may be a crank issue? The crank only has 1 oil port per rod, and consequently the rod bearing needs to drag the oil 1 round, before being oiled on the same spot?
Reply #79 on:
February 08, 2019, 10:57:05 am »
Looks like oil contamination from E85 & maybe some aeration of oil to me, center main looks pretty good for all the abuse it gets, also oil pressure like boost pressure is only a measure of resistance, its flow the bearings really need, thick cold oil gives lots of pressure but no flow which is why we pre heat oil
Reply #80 on:
February 08, 2019, 11:01:19 am »
Quote from: richie on February 08, 2019, 10:57:05 am
Thanks!
I never drive it before the oil is hot. But yeah, I admit to using thick oil
Maybe I should start to get parts for a dry sump system after all..
Reply #81 on:
February 08, 2019, 11:04:49 am »
Richie: Internal vs. external bearing grooves. Done any research?
Reply #82 on:
February 08, 2019, 21:21:31 pm »
I used plenty of both, never seen any real evidence of either being better or worse, more important to make sure oil holes line up and bearing is decent quality material
Reply #83 on:
February 08, 2019, 22:09:08 pm »
Quote from: richie on February 08, 2019, 21:21:31 pm
Jo said you’ve got silverlines in stock? Any good?
Berger
www.bugrent.no
Reply #84 on:
February 08, 2019, 22:48:04 pm »
Quote from: Erlend / bug66 on February 08, 2019, 08:56:03 am
You need to use a better oil, Ester base handles E85 very well, gives a stronger oil film and hangs on to metal longer. It`s all about
when
the oil film gives up
This is my simple religion:
-Be cool
-Don't be an asshole
Reply #85 on:
February 09, 2019, 15:54:07 pm »
Quote from: Berger on February 08, 2019, 22:48:04 pm
when
I'm sure oil plays it’s part also!
I’ll clean the case and internals up good and slap new bearings in it. Might do a dry sump, if the money is right..
I only need a few bits and bobs on the engine this year, so quite pleased!
Reply #86 on:
February 18, 2019, 14:13:04 pm »
While the car is in Sweden, the engine in pieces, and the transmission in plastic waiting to get re-sealed, I'm thinking about making the new exhaust
I think I need a new header, as the "CB-style" I have will interfere with everything.. Tubo will hit the rear valance at the minimum.
That said, I also need to make new plenums, or at least redo the ones I have. They will be too tall, at least the entrance pipes into the plenums.
I was hoping to not have to cut away the "roof" below the window inside the engine room.
Looking at old pictures, I'm hoping I can use the intake/TBs at all..
Last Edit: February 18, 2019, 14:15:48 pm by Erlend / bug66
Reply #87 on:
February 18, 2019, 19:01:52 pm »
Welcome to the world of race cars
Again
Reply #88 on:
February 18, 2019, 21:21:07 pm »
Hah! I’m not complaining.. I’m just breaking everything down, so I can sleep at night without crying
Reply #89 on:
February 18, 2019, 21:29:30 pm »
With all that room you have over trans now seems stupid to not move turbo forward anyway to help with weight distribution
5
