October 28, 2026, 16:35:43 pm
Hanibal1
Project CFC#1, turbo, back halfed and light
5
Topic: Project CFC#1, turbo, back halfed and light (Read 145526 times)
Re: Project CFC#1, turbo, back halfed and light
Reply #120 on:
May 19, 2019, 15:42:41 pm »
All runners welded and ported. Need to fill some metal in the porous aluminium
Reply #121 on:
July 16, 2019, 12:00:10 pm »
There is some progress at least
Reply #122 on:
August 27, 2019, 13:03:48 pm »
Nothing big to share really. Body and floor pan / cage is split. Need to give the body some love.
2+ cm fenders are ordered.
Mendeola 2D is sorted
Vertigate is sorted
Type 1 trans sold
Just need to do everything on the list :p
Reply #123 on:
January 19, 2020, 13:54:21 pm »
Mendeola is fitted, converted to 5’’ 300M axles from Rancho.
Body is rust welded, picking up the flip front on Tuesday.
New clutch discs is ordered from Black Magic.
Next will be the rest. Starting with the flip front, then fuel/water tank.
After that exhaust from scratch, intake etc etc
sonic
Reply #124 on:
December 29, 2020, 12:05:13 pm »
Looking good Erlend , almost a year since last update
Rgs/Erich
T11964
Reply #125 on:
December 29, 2020, 16:16:31 pm »
Just saw your manifoldweldings , you need to clean each bead after welding , normally it`s enough with a soft wirebrush ( brass) .
Reply #126 on:
December 30, 2020, 11:32:03 am »
I’ll make a longer update post over new year’s ..
Header is done, up pipe to the turbo is done, IC is done, new body is on (the previous body had a bad “kink” in it and did not fit straight),
Wiring is under way, fenders are mocked up in rear, and fits 28x11,5 DOT slicks under stock fenders on stock placements.
Last Edit: December 30, 2020, 11:34:41 am by Erlend / bug66
Reply #127 on:
December 30, 2020, 11:43:29 am »
New turbo, as the last did not quite survive being used over its potential.
New turbo is a BW S257 SXE.
Compressor:
Borg Warner 4" Inlet/2" outlet Ported Compressor Housing
Integrated Speed Port (Sensor Not Included)
57.15/76.20mm Billet Compressor Wheel w/ Extended Tip
Turbine:
69.56/61.43mm Turbine Wheel
Compressor wheel is just marginal bigger, but turbine is a lot bigger. Should work fine with the power output I’m after
brewsy
Reply #128 on:
December 30, 2020, 16:19:04 pm »
That is looking so awesome Erlend.
Please finish soon as we can see/hear it run!!
sonic
Reply #129 on:
January 01, 2021, 18:15:24 pm »
Looking very good Erlend
Rgs/E
5
