November 15, 2026, 19:37:27 pm
352349 Posts in 28966 Topics by 6931 Members
| | |-+  I have a question on a good case to buy for a 2442cc turbo??
Author Topic: I have a question on a good case to buy for a 2442cc turbo??  (Read 11805 times)
mac770
« on: July 27, 2018, 01:40:09 am »
I just had a lifter take out my CB case. I see the CB cases are clearance for 86mm crank but nut 88mm. Should I step up and get the Scat killer case? or is there something out there I should get?
« Reply #1 on: July 27, 2018, 06:53:14 am »
Can you existing case not be repaired? I have had them done a few times when lifter broke the case.
Scat don't have any cases at moment, TF1 is probably best choice with its dropped cam for 88mm crank but it isn't a simple bolt together, the normal ally cases will take a 88mm crank, they just might need a little hand clearancing depending on what rods you use
dragvw2180
« Reply #2 on: July 27, 2018, 13:15:32 pm »
If I remember correctly Mike at Autocraft told me his new cases are done also . Mega Machine in North Carolina has and does repair or install roller cam setups into the Cb Cases so it is more than possible to repair your case.
mac770
« Reply #3 on: July 31, 2018, 16:19:38 pm »
Just got back from camping. Thanks for the replys. I'm going to take the case into a local shop today and see what they have to say.
mac770
« Reply #4 on: August 07, 2018, 20:55:54 pm »
Found out my case can not be repaired. The lifter bore broke down to the oil passage. I'm going with the TF-1 case.
« Reply #5 on: August 08, 2018, 02:30:20 am »
You will love that case
