October 15, 2026, 09:27:38 am
How to connect a ballast resistor on an coil?
Topic: How to connect a ballast resistor on an coil? (Read 4714 times)
October 16, 2007, 13:32:18 pm »
Hello,
I've a simple electrical problem.
I don't find how to connect a ballast resistor on a coil.
I will use an electronic ignition and they say that if the coil make less than 3.0 ohms, I have to use a ballast to prevent problems.
Coil is stock VW coil. I also have an old Bosch blue.
Felix/DFL
Re: How to connect a ballast resistor on an coil?
October 16, 2007, 19:49:52 pm »
Hi
no problem. Here you go:
http://www.hot-spark.com/Installing-Hot-Spark.htm
Greetz,Felix
October 16, 2007, 19:55:11 pm »
Quote from: Felix/DFL on October 16, 2007, 19:49:52 pm
Hi
Greetz,Felix
Thank you very much
