October 12, 2026, 17:47:45 pm
| | |-+  Turbo head chambers
Author Topic: Turbo head chambers  (Read 5652 times)
« on: August 17, 2018, 12:29:53 pm »
Hi guys,
Looking for some knowledge here. I see cylinder heads for use on turbo aircooled engines have a large cc volume in the chambers and kind of understand that from a compression ratio point of view.
I've done something silly and started thinking! I have a pair of CB Wedgeport heads, 94 bore that have a 56cc chamber. These are currently on a n/a ida 2276cc motor.
Is there a way of re-working the chamber design to get more CC in them for turbo use? What cc should I aim for?
Thanks,
Lee
Martin S.
« Reply #1 on: August 17, 2018, 16:06:58 pm »
Aim for under 9:1. Unshroud intake valves and dish the pistons.  Wink
« Reply #2 on: August 17, 2018, 21:37:18 pm »
Thank you.
I know the valves were unshrouded when built so will have to try and gain it elsewhere?
Lee
Martin S.
« Reply #3 on: August 20, 2018, 15:39:50 pm »
The next best place is dishing the piston which we have talked about a lot on here lately. You don't want to do the easy thing of cutting the chamber semi-hemi, or adding deck by shimming or copper heads gasket.... or do you?
Before my motor was rebuilt as a 2332, it was a 1776 Berg style with 7:1 heads and SH cut. With 15psi the turbo gave that motor such a kick in the pants it was unbelievable and lots of fun to drive! It's still fun now, but before there was no secret that it was a turbo engine  Cheesy
