September 22, 2026, 03:39:20 am
| | |-+  Starting over
Author Topic: Starting over  (Read 15102 times)
Beastofabug
« on: September 18, 2018, 20:32:18 pm »
Hi guys after a nightmare weekend where my project went from this
to this
I'm guessing to was a faulty fuel line
trying to work out whats likely to be salvageable basically I'm going to remove the shell possibly sell if I can and rebuild from ground up again
a lot of parts look saveable
engine
transmission
floorpan
beam
even the brake discs look good
has anybody got any experience on what can realistically be saved
brewsy
« Reply #1 on: September 18, 2018, 20:58:43 pm »
Fuck no.
Sorry to hear/see that mate...
Beastofabug
« Reply #2 on: September 18, 2018, 21:02:51 pm »
thx brewsy
karl h
« Reply #3 on: September 19, 2018, 06:24:18 am »
that sux. what happened, did it burn in the garage?
Beastofabug
« Reply #4 on: September 19, 2018, 06:54:56 am »
It caught in the garage but managed to push it outside
Andrew
« Reply #5 on: September 19, 2018, 20:02:09 pm »
That's really bad news, hope your OK?
Beastofabug
« Reply #6 on: September 19, 2018, 20:19:14 pm »
I?m good burnt fingers had to shave beard off as got singed and obviously keep kicking my self for not checking fuel lines
Baz54
« Reply #7 on: September 19, 2018, 21:01:42 pm »
Oh crap that's everyone's nightmare. Good news your ok though .
Martin S.
« Reply #8 on: September 19, 2018, 22:54:18 pm »
A fire happened on my car when a gas line wasnt tight while in my buddys shop one time.
Luckily he was super quick with the shop air hose and put it out. I had no idea of that trick.
Right after he was pacing around going, adrenaline adrenaline.
That really sucks
« Last Edit: September 19, 2018, 22:56:27 pm by Martin S. » Logged
numbnuts
« Reply #9 on: September 23, 2018, 08:29:55 am »
I'm guessing that most of the floor pan will be salvageable
Anything rubber or plastic will have perished
Don't give up on it
2854cc 1956 cal looker coming to this space shortly
Beastofabug
« Reply #10 on: September 23, 2018, 09:32:59 am »
Good news is stripped the engine and short block,pots and barrels all look good heads and rocker gear need a good clean before I can assess. Transmission looks good but going to get it checked by the the guy who built it.
So not a complete right off
numbnuts
« Reply #11 on: September 24, 2018, 21:04:26 pm »
Cool, just need another body then or could that be salvageable?
If the roof is bent now about a door chop  Wink
« Reply #12 on: September 25, 2018, 07:05:38 am »
I don't think the body will be salvageable. Heat does funny things to metal, makes it weak. I'd even consider changing the pan halves, especially if you want to fit a cage to the replacement car.
Get the body off, then start measuring the pan for straightness and squareness.
Fire is my biggest fear as its just so unforgiving.
Beastofabug
« Reply #13 on: September 25, 2018, 07:30:46 am »
Shells on eBay at mo beyond my skills to try and repair going check chassis and rebuild from ground up
Then when done decide what I?m going to do for a body as have the space limitations of a single garage
Must admit keep having thoughts of sandrail or buggy but all depends on finances and what?s about at the time will take me at least a couple of months to do chassis
Garrick Clark
« Reply #14 on: September 27, 2018, 16:51:27 pm »
Build a quick buggy. It will get you back ON the track way faster than building a bug from the ground up.
Air cooled Engine builder
Beastofabug
« Reply #15 on: September 27, 2018, 16:57:00 pm »
My thoughts exactly may go sandrail over buggy
« Reply #16 on: September 28, 2018, 07:44:22 am »
There are rail type kits that bolt to a standard floorpan, so avoiding IVA. Worth a thought? I'd go for a LWB buggy (for the same reason) but move the seating position. Ali Southcombe had a wicked LWB drag buggy - use that for inspiration?
Beastofabug
« Reply #17 on: September 28, 2018, 08:32:30 am »
Marks dream shack do a frame that bolts straight down to stock chassis looks a bit like the army fast attack vehicle
But as no chassis shortening no Iva
Andy
« Reply #18 on: September 28, 2018, 15:06:02 pm »
It must be devastating for the fire to happen so close to finishing the car.
Moving forward I would think you would get much more use out of it if you rebuilt it as a bug, I presume it is going to be street legal .
We had a great summer but who knows what next year will be like.
Beastofabug
« Reply #19 on: September 28, 2018, 15:12:21 pm »
True I?ll decide after I?ve got the chassis done it?s always been a summer only car got a t4 as my daily
