September 19, 2026, 02:06:05 am
Bad Habit
Another fiat 600
Topic: Another fiat 600 (Read 47036 times)
Re: Another fiat 600
Reply #30 on:
September 29, 2019, 09:03:04 am »
Quote from: DaveN on February 18, 2019, 22:19:19 pm
Finally getting to build my engine 7 years later than planned after replacing all the parts Jeff Denham never supplied me even though they were already paid for.
Tell me more about those heads. Are these something you paid for and ever got?
Looks like angle flows but then not..... Built for different kind of manifold. Mikuni carbs comes to my mind when I see that.
Some of my cars:
DaveN
Reply #31 on:
September 29, 2019, 14:25:13 pm »
They are angle flow heads, one of the few parts actually got after waiting 4 years.
I still have loads of parts missing which he never supplied and I have had to buy again.
Sump,rockers,oil pump,pushrods and tubes, magneto, carb linkage, tinware, camshaft and cam gear, lifters, all crankshaft hardware, clutch pressure plate and disc, cylinder head studs, all the bearings . Probably a few more things too
Jeffery Denham, liar, thief and not to be trusted.
Last Edit: September 29, 2019, 14:32:57 pm by DaveN
DaveN
Reply #32 on:
October 24, 2019, 18:35:52 pm »
My Winter project . Nothing to do to the fiat so I’m going to be working on this. I plan to Refit the interior, change the front seats, loose the MH DOTS for a set of radials, I did contemplate cutting out the cage but decided against it. I can drive the car anywhere in its current set up but now I’m going to make it more of a road car
Last Edit: February 07, 2021, 22:07:40 pm by DaveN
DaveN
Reply #33 on:
October 27, 2019, 11:18:48 am »
Not sure this will pass MSA tech inspection but I want to make sure I get my new seats in the best position.
Last Edit: February 07, 2021, 22:07:50 pm by DaveN
Reply #34 on:
October 27, 2019, 13:58:47 pm »
I think they are probably stronger than some steel efforts I've seen
What you doing with your old bug seats?
DaveN
Reply #35 on:
October 27, 2019, 16:52:31 pm »
Probably! I’m just messing around with seat heights/ position before I start making something.
Don’t know about the seats probably put them on the shelf till I need them
DaveN
Reply #36 on:
November 03, 2019, 17:04:00 pm »
New seats and frames finished! Big thanks to Danny for the loan of his welder and work shop. Not going to refit the interior now, Too heavy and I don’t think it’s going make much difference so I will continue using ear plugs.
Last Edit: February 07, 2021, 22:08:03 pm by DaveN
Reply #37 on:
November 10, 2019, 06:59:44 am »
Should of lowered those seats down about 1-2cm so you could of put 3-4 cm of foam between those seats and your bum for those moderate length drives
…. a little experience speaking here....
Of course you could just put a real nice Sparco seat in for you and leaving the Kirkey for the passenger.... Cuts down on the number of times the wife will want to come along LOL...
http://selvedgeyard.com/
DaveN
Reply #38 on:
November 10, 2019, 20:19:50 pm »
I trial fitted a friend’s seat
Last Edit: February 07, 2021, 22:09:31 pm by DaveN
DaveN
Reply #39 on:
April 05, 2020, 20:39:08 pm »
New seat covers fitted and found my LM1
Last Edit: February 07, 2021, 22:08:16 pm by DaveN
