October 28, 2026, 17:45:36 pm
352330 Posts in 28962 Topics by 6929 Members
Latest Member: Hanibal1
| | |-+  72 street bug
Pages: 1 [2] Print
Author Topic: 72 street bug  (Read 97229 times)
Flc
« Reply #30 on: February 28, 2019, 09:37:38 am »
[ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] just got to try to not warp it all , while welding
« Reply #31 on: March 01, 2019, 11:03:05 am »
I did put Cookies on the race car I sold a couple of years ago - it's in the Stew Rat thread in the In Da Werks  section. They were 6" on the front and 7" on the back, on drilled discs and drums. Front fitted fine with 175/65's, back could have done with short axles.
I've just been looking for photos of the back end but haven't got any to hand. I'll look again later!
« Last Edit: March 01, 2019, 11:11:45 am by Neil Davies » Logged
Flc
« Reply #32 on: April 22, 2019, 10:37:39 am »
Not updated this in ages , but it’s been the typical chop,bang, weld , repeat for ever, [ Attachment: You are not allowed to view attachments ]
Had to repair in sections which took more messing around and time
Then fitted boot floor repair section
Flc
« Reply #33 on: April 22, 2019, 10:42:21 am »
Then replaced rotten inner sections that look ok when I started poking around [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
Would have been quicker to find a decent cut ,but I need the practice 😁
Flc
« Reply #34 on: April 22, 2019, 10:45:56 am »
Drivers side has been easier as I got a full quarter that had been fitted to another car so some repairs to tidy and fits a treat [ Attachment: You are not allowed to view attachments ]
Flc
« Reply #35 on: April 22, 2019, 10:50:23 am »
That’s better [ Attachment: You are not allowed to view attachments ]
That about brings things up to date not shown is the door pillar bottom repairs from hookys, the typical repair next is boot floor repair and then rear engine bay trays and seal lip repair (again a hookys part that looks to be the exact size 😎)
Flc
« Reply #36 on: June 17, 2019, 13:53:45 pm »
« Last Edit: June 18, 2019, 08:30:55 am by Flc » Logged
Flc
« Reply #37 on: June 17, 2019, 15:42:03 pm »
Been a bit quiet with this,  nothing much to report,  just lots of cut/bang/weld , almost completed the panel work now just the dash to convert to rhd and scuttle repairs [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
Hopefully I can then get on with making this go faster  Grin
« Last Edit: June 18, 2019, 08:28:25 am by Flc » Logged
Flc
« Reply #38 on: December 18, 2019, 17:34:38 pm »
So more of the same  but turns out the fibreglass short bonnet turned out to be a long one [ Attachment: You are not allowed to view attachments ]
I did toy with using it but want this to be period correct (mid 70's late bug) not even sure why but I've already bought Europa bumpers/overiders ect so into storage it went and a fairly decent late bonnet sourced [ Attachment: You are not allowed to view attachments ] fast forward loads more welding stuff to include extending one heater channel about 10mm to reach bulkhead panel, converting shell from lhd to right about as much fun as it sounds and making/fitting an edge to front quarter to door seam. Now done and just requiring a bit of filler here and there [ Attachment: You are not allowed to view attachments ] then onto dash board mods [ Attachment: You are not allowed to view attachments ]
Flc
« Reply #39 on: February 16, 2020, 10:14:29 am »
Finally got a glass short bonnet, 3 time lucky and it looks like it grew there, very happy
« Last Edit: February 16, 2020, 10:31:48 am by Flc » Logged
« Reply #40 on: February 16, 2020, 11:48:03 am »
glad you found a good one! Cool
Flc
« Reply #41 on: February 16, 2020, 19:24:46 pm »
[ Attachment: You are not allowed to view attachments ] thanks Andy
Yes finally got there in body colour primer now
« Last Edit: February 16, 2020, 19:27:05 pm by Flc » Logged
Flc
« Reply #42 on: February 16, 2020, 21:58:53 pm »
In other news i finally managed to track one of these down
A dog house no heat puma fan shroud😎
A fairly rare part , I'll be fitting flaps and a venturi ring
Flc
« Reply #43 on: February 17, 2020, 00:24:53 am »
[ Attachment: You are not allowed to view attachments ] Picture trial fitted, needs a small adjustment for the alloy case
« Last Edit: February 17, 2020, 08:51:56 am by Flc » Logged
Flc
« Reply #44 on: April 23, 2020, 22:07:27 pm »
Finally got body back on chassis, soon to start actually building a car 😎 [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
« Last Edit: April 23, 2020, 22:09:01 pm by Flc » Logged
The Badger
« Reply #45 on: May 25, 2020, 21:04:13 pm »
Some great work being done !
Look forward to seeing the end result 👍
Flc
« Reply #46 on: September 13, 2023, 20:50:58 pm »
Best update this as its only been 3 year's,  Shocked
The car was completed with a 2109cc motor that never really ran nice, so long story short I pulled it out and added some cc and compression  Cool this was a few weeks ago when it finally went back in as a 2276 with 10.5:1 compression and the f8 cam on straight cut cb adjustable gears was set with 2 degrees advanced washers (was actually straight up) and 45 dell's,
That fixed it  Grin now it's the car I always wanted.
Fast capable and just enough scary to keep it fun.
Now to put some miles on it before summers completely done.
Flc
« Reply #47 on: September 13, 2023, 22:44:37 pm »
76mm and 82mm cranks not a lot of difference to see, but it's certainly woke her up
alex d
« Reply #48 on: September 15, 2023, 11:15:01 am »
FK8 with 10.5:1 cr? I'm assuming you run high octane petrol?
Flc
« Reply #49 on: September 15, 2023, 18:01:06 pm »
Yes we have 99 Ron shell super unleaded 5% ethernol.
Pages: 1 [2] Print
