September 24, 2026, 23:30:43 pm
| | |-+  Return fuel line ?
Author Topic: Return fuel line ?  (Read 6102 times)
glassback kid
« on: October 07, 2018, 10:16:32 am »
Hi guys need some advise on whether I need to run a return fuel line, I am going to put a 8mm kunifer pipe through my 58bug and replace the mechanical fuel pump with lucas low pressure 2.5-4.5 psi electric pump this will be running through a filter king/regulator and feeding a pair of 44idfs on my 1914 motor, the way I look at is with the motor running the carbs are taking the fuel it needs so shouldn't need a return for unused fuel or excess pressure
PPRMicke
« Reply #1 on: October 07, 2018, 11:24:19 am »
No
glassback kid
« Reply #2 on: October 07, 2018, 16:05:20 pm »
No
Cool, thanks  thats the answer I need 👍
karl h
« Reply #3 on: October 08, 2018, 07:32:22 am »
if you ever will run FI you will need a return line. if you go to the trouble of replacing the line, just put two in to be safe for the future....just my 2c
« Reply #4 on: October 08, 2018, 12:04:11 pm »
Wouldn't you just use the stock line for EFI fuel return?
