September 24, 2026, 22:38:15 pm
Technical stuff
Return fuel line ?
Topic: Return fuel line ? (Read 6093 times)
glassback kid
Return fuel line ?
October 07, 2018, 10:16:32 am »
Hi guys need some advise on whether I need to run a return fuel line, I am going to put a 8mm kunifer pipe through my 58bug and replace the mechanical fuel pump with lucas low pressure 2.5-4.5 psi electric pump this will be running through a filter king/regulator and feeding a pair of 44idfs on my 1914 motor, the way I look at is with the motor running the carbs are taking the fuel it needs so shouldn't need a return for unused fuel or excess pressure
PPRMicke
Re: Return fuel line ?
October 07, 2018, 11:24:19 am »
No
glassback kid
October 07, 2018, 16:05:20 pm »
Quote from: PPRMicke on October 07, 2018, 11:24:19 am
No
Cool, thanks thats the answer I need 👍
karl h
October 08, 2018, 07:32:22 am »
if you ever will run FI you will need a return line. if you go to the trouble of replacing the line, just put two in to be safe for the future....just my 2c
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
October 08, 2018, 12:04:11 pm »
Wouldn't you just use the stock line for EFI fuel return?
