September 25, 2026, 00:41:54 am
Technical stuff
Rear axle spacers and effect on ride
Topic: Rear axle spacers and effect on ride (Read 5699 times)
Richierich56
October 09, 2018, 23:49:16 pm »
Been messing around with various spacers on my Oval to get the rims to sit where I want them. Running short axles so need to space some to get the tyres out a bit and also clear the adjustable spring plate steps with the tyre size. Effectively now, I'm running 5+3mm spacers either side (so 8mm total each side) and have noticed at around 55 mph on the motorway, the car has a shimmy/shake - almost like what you would get with wheels being way of of balance. Tyres are new and balanced correctly so what I was wondering if someone can answer is, can too much spacer OR effectively lengthening the axles have this effect? Seeing as it didn't do this before I added the 3mm spacers, I guess I may have the answer but thought I would ask the opinions of those of you more knowledgeable than I.
Thanks in advance.
mr horsepower
Re: Rear axle spacers and effect on ride
October 11, 2018, 17:19:50 pm »
Hi
Is your wheel centered at the hub?
Thats what i did to make it smooth @200kmh
Gr henri
letku
October 11, 2018, 18:28:58 pm »
Hi
Have 35mm spacers no problem so far.
What is wheel size? 55mph = 95km/h? You are off balance i think.
numbnuts
October 11, 2018, 21:35:21 pm »
Do the spacers have the spiggot profile rich? Need this to centre the wheel otherwise it could be slightly out
2854cc 1956 cal looker coming to this space shortly
Richierich56
October 11, 2018, 23:12:33 pm »
Hey mate, I'm pretty sure they don't you know. I'll have a look on the weekend.
