September 23, 2026, 22:07:02 pm
| | |-+  Which P&Cs Should I Buy???
Author Topic: Which P&Cs Should I Buy???  (Read 5802 times)
Motox166
« on: October 19, 2018, 07:46:25 am »
Scat kit $572
https://www.scatvw.com/product/94mm-stroker-race-cylinder-and-lightweight-wiseco-piston-kit/
CB Kit $757
http://www.cbperformance.com/product-p/racereadymahle.htm
Aircooled.net $630
http://vwparts.aircooled.net/JE-Forged-94mm-B-P-C-Set-VW9400T1SJE-p/vw9400t1s-je.htm
Or Mahle $400ish
Or Huh
Thinking there's a middle between light and high rpm and heavy and long lasting?
And I'd like to run some No2 - 75, 150 shot? What can these handle reasonably? Dry or wet?
Building a:
2165
L7 Heads 77cc runners w/ L5 valves 40x35
86c w/ 1.4s - thinking 106 LC?
10:1
Dual 44s
1 3/4 exhaust
7500 or 8000 max rpm
Vw650 springs, Ti retainers, straight cut timing gears
As41 mag with bushed lifter bores, full flow
Bugpack crank, pauter rods
Shooting for 180hp+ at the crank.
Use:
70 Baja Bug, mostly a fun after work/ weekend warrior.
Once in a while, play around in the Oregon sand dunes.
002 bus box, 30"x 13" sand paddles for sand drag racing and 32" for the street.
_________________
Erlend / bug66
Global Moderator
SCC Event
« Reply #1 on: October 22, 2018, 10:55:49 am »
The kit from CB already comes stress honed. The others don't?
My Wiseco pistons still lives after 7 years of mild to semi-wild boost.
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
