October 13, 2026, 21:19:03 pm
| |-+  For sale!
| | |-+  MSD HVC Blaster Coil & MSD 8.5mm Super Conductor Wires
Author Topic: MSD HVC Blaster Coil & MSD 8.5mm Super Conductor Wires  (Read 3006 times)
SteveW
« on: October 23, 2007, 20:26:26 pm »
This has not had much use. Its as the picture below. Comes with 4 mounting bolts and original box. Costs £139 brand new from Speedshop.
Offers around £110!
The Blaster HVC Coil is right at home on the street or strip. The Coil is designed to produce maximum power with an MSD 6 Series Ignition Control. Special windings and material were chosen by MSD engineers to efficiently produce High Voltage and Current. Low primary resistance allows the coil to take in all of the MSD's energy and instantly step up the voltage combined with a high amount of current. This combination delivers a powerful spark to the plug for complete combustion in the cylinder. The coil windings are encased in epoxy and held secure in a heavy duty aluminum housing. The tall secondary tower accepts an HEI style plug terminal and boot.
Also set of used MSD 8.5mm Super Conductor Wires.
They work fine but are used bit mucky but ideal for a spare set, or if your engine isnt pristine!
£42 brand new!
£20
Steve
1961 Oldspeed Beetle
1970 Stock Beetle.
SteveW
« Reply #1 on: October 29, 2007, 16:49:15 pm »
Up they go! Offers...
Adele
Smiley
Steve
1970 Stock Beetle.
