October 12, 2026, 18:06:43 pm
| | |-+  Nitro+turbo...
Author Topic: Nitro+turbo...  (Read 33999 times)
SplitMan
SCC Crew
« on: March 01, 2006, 15:15:35 pm »
Makes this Ghia go low nines on the South-East dragstrips... Go NitroMike!
n2o
« Reply #1 on: March 06, 2006, 18:27:36 pm »
nitromethane?
9.88 @ 134.25 mph
twoghias
« Reply #2 on: March 10, 2006, 12:06:16 pm »
Splitman, you got a picture of my best side. Cheesy
The only nitro part of the car is me...Nitro Mike. I got that nickname when I had a street ghia on the juice.5 different Mike's race out of the same shop. Every Mike got a nickname to keep us all from turning our head everytime someone called out "MIKE".
Quote
nitromethane?
mechanical alky injected, turbo.
NO nitrous, NO nitromrthane.
24 lbs. boost, and start rowing my way too short gears as fast as you can, and hang on.
Hope to set a new Hot VW's AS/X 1/8 mile record this weekend at the SEVWA race
Current record is 6.21 and was taken from this car in 1999.
Abrakadabra held this record from 1993-1999 @ 6.22
I have gone as fast as 6.13 @ 115 mph at our local track. I need to be at a all VW 1/8 mile event to retain this record back to Abrakadabra.
Quote
Can you give us some more info about it?
Best rgs
1350 lbs. Nothing really special except maybe the turbo is matched very well and I dripped a lot of sweat on it building the motor and tranny. Lots of R&D in making the chassis work well. Best 60 foot is 1.28
Engine: 2275cc VW
Turbos: TO4B  super-V compressor wheel and O-exhaust wheel and .96 ar exhaust housing
Boost Control: mechanical wastegate
Boost Pressure (psi): up to 24lbs. so far!
Pistons: Wiseco 94mm
Rings (seals): Wiseco
Heads: 42mm x 37.5mm CB Performance (right out of the box!!!)
Connecting Rods: Pauter 5.7 inch Chevy Journal
Intake: Custom made
Exhaust: Custom equal length 46" primary pipe
Ignition: MSD 6AL & MSD Dist./blaster 3 coil
Spark Plugs: NGK-B9ES
Fuel: Methanol
Pulley: Chineese aluminum
Transmission: VW 4-speed Bus 002
Gears: RP-4.86 3.78/2.21/1.50/1.04 (this is my asriprated gearbox, I have no other)
Clutch: Chassis Shop double-disk
Flywheel: Scat flanged 82mm crank
Shifter: Gene Berg
Wheels: Marsh Racing-carbon fiber outers/al. inners
Tires: M&H 30 x 9 x 15 (trying to make up for those really short gears!!!)
"If it takes little or no talent, I have both."
« Reply #3 on: March 12, 2006, 20:20:26 pm »
Much appreciated, thanks Twoghias!
