October 13, 2026, 02:50:28 am
54mm ducati throttle body.
Topic: 54mm ducati throttle body. (Read 23714 times)
Bad bug
November 04, 2018, 15:31:43 pm »
Good day All,
Can anyone tell me what is the measurement of the narrowest point as the bore of the throttle body gets to the butterflies.
Bad bug
Re: 54mm ducati throttle body.
November 10, 2018, 20:27:13 pm »
No answer, no one has ever used these TB's on an engine.
Eddie DVK
November 11, 2018, 09:48:19 am »
I can t help you, but took some picture of a drag beetle at SCC 2018 with Ducati trottle body s on them.
Maybe some one here knows the owner.
Regards Edgar
Regards Edgar
Bad bug
November 11, 2018, 15:23:41 pm »
Eddie any help is appreciated. I am considering putting this on a large t4 engine injectors will be placed in the original position. If needs be i will add and additional four close to the heads.
Bad bug
November 11, 2018, 15:32:30 pm »
What pattern is he using an IDA or wider to fit the TB"s.
November 11, 2018, 17:21:51 pm »
Quote from: Eddie on November 11, 2018, 09:48:19 am
Regards Edgar
Its Andreas Jonsson's car
PPRMicke
November 11, 2018, 17:48:24 pm »
Quote from: Bad bug on November 11, 2018, 15:32:30 pm
The intake are shortened IDA
You have to have a distance piece with ducati bolt pattern
/// Micke
Bad bug
November 13, 2018, 00:20:10 am »
Does anyone have any videos of Andreas racing his bug, is he a member here on this forum.
numbnuts
November 13, 2018, 13:31:58 pm »
What Ducati are these off?
2854cc 1956 cal looker coming to this space shortly
Eddie DVK
November 13, 2018, 13:33:13 pm »
I like those tb's, and knew there was an topic on here before. Found it!
http://cal-look.no/lounge/index.php/topic,23790.30.html
Starts at the bottom of page 2.
Last Edit: November 13, 2018, 13:37:06 pm by Eddie
Regards Edgar
OveF
November 13, 2018, 14:28:07 pm »
Quote from: Bad bug on November 13, 2018, 00:20:10 am
Here's one from facebook:
https://www.facebook.com/andreas.jonsson.98434/videos/1336843276418204/
AJ
November 18, 2018, 09:54:39 am »
Just saw this post.
Yes, it's my car, throttle bodies pictured above.
I made a new shaft for the butterflies to mount them in line as it did't worked out with the ducati set up, the geometry are different when you mount them both horizontally.
They are mounted on angle flow IDA intakes using a conversion plate, i also borred them out to 56mm
Eddie DVK
November 18, 2018, 10:01:27 am »
Quote from: AJ on November 18, 2018, 09:54:39 am
Just saw this post.
Cool...
They seem to be working for you?.
As I remember correctly you where driving in the 10's at SCC.
Regards Edgar
PPRMicke
November 18, 2018, 11:14:03 am »
Quote from: Eddie on November 18, 2018, 10:01:27 am
Just saw this post.
Cool...
for info
10.31@209.90
( steel car
There are pictures here
https://www.facebook.com/pg/Swedish-West-Coast-VW-Drag-Racers-792580740944902/photos/?ref=page_internal
/// Micke
Last Edit: November 18, 2018, 11:20:45 am by PPRMicke
Bad bug
November 18, 2018, 19:15:59 pm »
Just saw this post.
What size engine did you have them on. I am thinking of using these on a 2.8 or 2.9ltr t4 engine. How much power di you make on your engine and what size was it.
PPRMicke
November 18, 2018, 20:18:39 pm »
Quote from: Bad bug on November 18, 2018, 19:15:59 pm
Just saw this post.
Oxy 4"x 80 mm Head Ms 250 313 hk
/// Micke
Bad bug
November 18, 2018, 21:49:50 pm »
Quote from: PPRMicke on November 18, 2018, 20:18:39 pm
Just saw this post.
/// Micke
Jesus have mercy. I wanted to do a 4 inch bore oxy with an 80mm crank but the guy doing the kit wasn't interested in doing 4 inch waterboxer heads to run on aircooled sleeves so now i have the 80mm waterboxer crank and case converted to support 94mm bore. The 2.2ltr oxy will be my first engine followed by the t4.
PPRMicke
November 18, 2018, 22:05:28 pm »
Quote from: Bad bug on November 18, 2018, 21:49:50 pm
Just saw this post.
/// Micke
Sweden made cylinders 😊 in Swedish steel 😊
[attachment=1 [ Attachment: You are not allowed to view attachments ]
Last Edit: November 18, 2018, 22:51:17 pm by PPRMicke
Bad bug
November 19, 2018, 02:09:29 am »
Who makes these liners and can they be made for the T4 engine. I am looking at options as i also have on my mind the deutz liners.
PPRMicke
November 19, 2018, 11:25:40 am »
Quote from: Bad bug on November 19, 2018, 02:09:29 am
No
the question of type 4 There was no one interested
(I do not want to be stupid but type4
There are so few heads for those that flow well on the exhaust side)
/// Micke
henk
November 22, 2018, 17:53:56 pm »
Quote from: numbnuts on November 13, 2018, 13:31:58 pm
I think ducati 999.
Henk!!!
Bad bug
November 25, 2018, 12:57:40 pm »
Quote from: PPRMicke on November 18, 2018, 22:05:28 pm
Just saw this post.
/// Micke
Who made these liners.
PPRMicke
November 25, 2018, 20:38:35 pm »
Quote from: Bad bug on November 25, 2018, 12:57:40 pm
Just saw this post.
/// Micke
Peter Servais i sweden
/// Micke
