September 26, 2026, 09:12:11 am
Technical stuff
4th GEN CB Performance EFI box
Topic: 4th GEN CB Performance EFI box (Read 5377 times)
runningmonkey
January 07, 2019, 13:48:32 pm »
Just after a bit of advance
Iv just finish fitting the CB turbo kit to my car and I am nearly ready for a first time start up using the 4th Gen EFI box.
Is there anything I need to know before I turn the key?
Do I need to update software or plug my laptop in and adjust anything? Or is everything preset?
Many thanks in advance
Tufty65
Re: 4th GEN CB Performance EFI box
January 07, 2019, 23:05:26 pm »
If it’s anything like their others, then they should of supplied a base map to the spec of your engine which needs to be loaded into the ecu then things like calibrate the TPS before start up then basic timing adjustment when running.
Outlaw Flat Four 35
12.64 @ 106.25mph
