April 19, 2024, 17:07:50 pm
350680 Posts in 28573 Topics by 6819 Members
Latest Member: Umanisti
| | |-+  Porsche 914 gauges
Author Topic: Porsche 914 gauges  (Read 2148 times)
VWGlassee
« on: January 21, 2019, 21:15:18 pm »
These 914 gauges arrived today. The speedometer will be mounted in the left dash grill. The rpm gauge i want to mount in the original speedometer hole.
Has anybody else done that? And how? Can’t find any photos on the internet of it.
I was thinking to put these (see photo) from the original speedometer on the rpm gauge. Don’t know if this will work Smiley
Yannick
Brian Rogers
« Reply #1 on: January 22, 2019, 07:01:06 am »
http://cal-look.no/lounge/index.php/topic,5626.0.html
Read the entire thread, it in there somewhere.
« Reply #2 on: January 22, 2019, 08:46:25 am »
Chris's car has a 914 gauge cluster that's been welded in.
If you want to run the Porsche tach in place of the VW speedometer. Simply grind off the lip that holds the rings in place.
Go at it little by little, at some point the tachometer will fit in snugly with no need to hold it in place otherwise.
VWGlassee
« Reply #3 on: January 22, 2019, 13:53:02 pm »
Allright, thanks!  Cool
Ron Greiner
DKP II
« Reply #4 on: January 23, 2019, 23:49:44 pm »
When I put the 911 tach in my ghia, I had it dampened so the needle doesnt bounce around and had mounting studs attached to the back of the guage
I had these mounting studs attached to the speedometer also.
