November 02, 2026, 19:55:33 pm
7.21@177mph flat 4 door powered car, is a 6second pass possible now?
Topic: 7.21@177mph flat 4 door powered car, is a 6second pass possible now? (Read 80709 times)
Basti
Re: 7.21@177mph flat 4 door powered car, is a 6second pass possible now?
Reply #30 on:
January 28, 2019, 13:35:26 pm »
not with 4 gears in my opinion....
- black 62 cal look beetle
- Pro Mod Race car
Erlend / bug66
Global Moderator
SCC Event
Reply #31 on:
January 28, 2019, 13:37:25 pm »
Just order a 5 speed sequential Mendeola
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
Basti
Reply #32 on:
January 28, 2019, 13:47:13 pm »
ist in my car
- Pro Mod Race car
Erlend / bug66
Global Moderator
SCC Event
Reply #33 on:
January 28, 2019, 13:59:28 pm »
Quote from: Basti on January 28, 2019, 13:47:13 pm
ist in my car
No worries then
The '67:
The '59:
Not yet..
Reply #34 on:
January 28, 2019, 19:02:42 pm »
Quote from: Erlend / bug66 on January 28, 2019, 13:33:59 pm
Sooooo,
with a double a-arm, 4-link or IRS rear, 1200hp and airshift, you should be able to match the car
We are going to try and see if that theory is correct
Reply #35 on:
January 28, 2019, 19:54:00 pm »
To add to that, Basti is correct, 4 gears aren't enough, I think really it needs a 6 speed to make it at all possible, and the way a conventional cars rear suspension works if its 4 link solid axle compared to our cars is very very different, I already read that its easy "just add enough weight at front to give same front to rear weight ratio as front engined car" but its much more complicated than just that
Reply #36 on:
January 28, 2019, 21:39:47 pm »
Quote from: richie on January 28, 2019, 19:54:00 pm
If it was easy then everyone would do it. However it is nice to see that innovation is pushing the ET down to a new level and I`m sure it will creep a fair bit further down sooner rather than later when I see that car go and looking at the 60ft.
-BB-
Last Edit: January 29, 2019, 08:56:53 am by BeetleBug
Erlend / bug66
Global Moderator
SCC Event
Reply #37 on:
January 29, 2019, 00:22:03 am »
6speed sequential transaxle is Albin, right?
The '67:
The '59:
Not yet..
Basti
Reply #38 on:
January 29, 2019, 08:05:39 am »
Yes but never used in dragrace if i am correct....
- Pro Mod Race car
Reply #39 on:
January 29, 2019, 08:56:45 am »
Quote from: Erlend / bug66 on January 29, 2019, 00:22:03 am
Quote from: Basti on January 29, 2019, 08:05:39 am
Yes it is and yes not to my knowledge it hasn't yet
Erlend / bug66
Global Moderator
SCC Event
Reply #40 on:
January 29, 2019, 09:37:42 am »
Quote from: richie on January 29, 2019, 08:56:45 am
I guess it's a cost thing? 25k$ without options
But guess it should be strong enough? I even believe they have a 11,5" RP option?
The '67:
The '59:
Not yet..
mikko k
Reply #41 on:
January 29, 2019, 12:48:59 pm »
https://weddleindustries.com/products/1000165/1002797
Reply #42 on:
January 29, 2019, 19:23:48 pm »
Quote from: Erlend / bug66 on January 29, 2019, 09:37:42 am
cost is a big factor & compared to the liberty the cost of this is insane, but in a dream world where I could afford it the case would be my main concern, I know Pety had issues with the 5 speed mendy case cracking and needed a billet one to make it strong enough and at $25k plus it would need to be strong enough
Erlend / bug66
Global Moderator
SCC Event
Reply #43 on:
January 30, 2019, 00:48:51 am »
Quote from: richie on January 29, 2019, 19:23:48 pm
What’s the cost of a liberty, custom rear axle and a light driveshaft?
The '67:
The '59:
Not yet..
Reply #44 on:
February 01, 2019, 21:35:03 pm »
Liberty now does a 7 speed.
Some of my cars:
Berger
www.bugrent.no
Reply #45 on:
February 02, 2019, 12:18:00 pm »
Quote from: richie on January 25, 2019, 22:23:55 pm
Yes its front engined but the Volkron[ from Puerto Rico] aircooled flat 4 turbo power steel bodied beetle just ran 7.21@177mph having gone &.35@170mph earlier today at Speedworld in florida, mph is still way down so looks like its possible to see a 6 second vw door car in near future
This is cool and they have my respect for the results they make with a flat-4 engine, but it`s not
by fare
comparable with a 7-second pass with a manually shifted rear engine beetle
So to me they might as well put a V8 in the front of it, it`s not a "real" beetle...
This is my simple religion:
-Be cool
-Don't be an asshole
Reply #46 on:
February 02, 2019, 17:29:03 pm »
Quote from: Berger on February 02, 2019, 12:18:00 pm
by fare
Yep it is totally different from a rear engine manually shifted clutch car which is a whole world of pain harder
but its still cool, I kind of agree but anything flat 4 aircooled based is more interesting to me than a V8, I have had way to many people say New cabrio isn't a real VW as its a chassis car & there was a whole load of bullshit about it after i ran a 7 from the haters
, it gets hard to define what is really a VW still when its a race car.
To me old cabrio is about as real as you can get going quick & be safe[full stock floorpan,stock suspension,stock VW brakes
,VW trans with syncros on every gear using a clutch for every shift etc etc], but am sure others would disagree as its not how Karmann built it
Berger
www.bugrent.no
Reply #47 on:
February 02, 2019, 21:43:34 pm »
Quote from: richie on February 02, 2019, 17:29:03 pm
by fare
Well, everyone have different criteria's, but if flat 4 engine is the only one, mid 6`s I believe is the time to beat..?
I believe I recently saw a Datsun drag car with a front mounted flat 4 turbo engine..? Impressive...
It have to be flat 4, it have to be rear engine and it have to look like a VW, that is my criteria's. So your New Cabrio, The Hater Maker, Red Baron, Skinne Beetle etc are the real deal fast VW`s
-Be cool
Ragtop
8.93 at SCC 2012
Reply #48 on:
February 10, 2019, 19:43:46 pm »
I believe they ran out of rpms on the 7.21 run. So I think they went as fast as the tranny could go
Saw that the tranny is for sale.
Reply #49 on:
February 11, 2019, 10:27:04 am »
1-7 speeds.
You choose your needs and if you have the budget, just go for it!
http://libertysgears.com/our-products/extreme-t-transmissions/
.... and if you want the "best" launch, you go with a Bruno/Quick Drive (plus work with a company that does bolted converters so you can modify them for best adaption of your needs) just like in the pictures
Last Edit: February 11, 2019, 10:29:36 am by Frallan
Some of my cars:
Erlend / bug66
Global Moderator
SCC Event
Reply #50 on:
February 11, 2019, 10:58:41 am »
So they can't just swap some gears out?
The '67:
The '59:
Not yet..
Reply #51 on:
February 11, 2019, 11:26:39 am »
Of course possible if you only want more top speed.
Change fourth gear.
Now what happens then to the harmony of what you just had?
Now finding a "sweet spot" and getting that traction and ET is not likely anything you wish to fiddle with too much.
Anything is possible but every change can be like starting over from the beginning.
A must safer move is to add a new gear.
I asked Ibrahim Colon who is part of the team what they intend to do. Lets see if he answers.
Some of my cars:
karmi
Reply #52 on:
February 14, 2019, 00:37:22 am »
by fare
Only flat 4 aircooled rockt
andy198712
Reply #53 on:
February 14, 2019, 18:21:21 pm »
is there an engine behind that massive turbo
what a beast! i think the build was probably more than my home!
Reply #54 on:
March 24, 2019, 21:05:50 pm »
7.18@188mph today, they are creeping nearer
Reply #55 on:
March 24, 2019, 21:12:02 pm »
7.10.....
Some of my cars:
Reply #56 on:
March 25, 2019, 15:03:11 pm »
Quote from: Frallan on March 24, 2019, 21:12:02 pm
7.10.....
Hi Frallan
I cant find any info on it going this quick, where did you see that it did?
Reply #57 on:
March 25, 2019, 16:35:33 pm »
Nope Richie! I read it on one of my "latino" speaking feeds but then it did not come up anymore so I think it might just be a comment that they are in the 7.1 range, which in fact is 7.18.
Sorry about that!
Some of my cars:
Reply #58 on:
March 25, 2019, 17:08:09 pm »
Quote from: Frallan on March 25, 2019, 16:35:33 pm
Sorry about that!
Ok
Reply #59 on:
March 26, 2019, 02:12:22 am »
I wonder about the power transfer efficiency between the stock transaxle and a front engine arrangement.
I think the weight would be similar in the end, maybe a bit heavier for front-engine, but for a low-HP setup perhaps the stock layout is quicker still.
Maybe?
Dunno.
