September 26, 2026, 04:51:51 am
Technical stuff
043 head info
Topic: 043 head info (Read 12975 times)
Glauco
043 head info
February 06, 2019, 15:42:49 pm »
could anyone give me some more info on the heads I got here?
They are mexico 043 heads, with 44x37.5 stainless valves, a lot of welding and a lot of porting done.
don't have any flownumbers or what so ever, the guy I got them from didn't now either, he bought them without knowing what to use them for..
one head has MR stamped in it, the other JK, maybe that someone knows who might of made these? never seen the bolt patern for the intakes like that neither..
thanks!
glauco
Glauco
Re: 043 head info
February 06, 2019, 15:44:48 pm »
exhaust ports say OS1 36
Last Edit: February 06, 2019, 20:25:34 pm by Glauco
dangerous
Re: 043 head info
February 06, 2019, 21:38:44 pm »
The manifold flange and offset valve guide speaks Autocraft to me. My guess is pre 1983.
Pedalpusher
Re: 043 head info
February 07, 2019, 08:08:30 am »
Offset valve guides, could you explain a little? Never heard of it, what's the benefit? Only to move valves a little?
-Mikko-
Glauco
Re: 043 head info
February 07, 2019, 08:14:15 am »
the hole in the valveguide is off centre,
don't have better pictures for now, but you get the picture.
with this type of guides you can put the valves further from each other..
no idea if it is safe to use?
Glauco
mikko k
Re: 043 head info
February 07, 2019, 08:55:21 am »
Often used to get bigger valves. It is safe to use.
alex d
Re: 043 head info
February 07, 2019, 09:09:32 am »
those chamber look small, guess they used to be in a high compression race car?
Glauco
Re: 043 head info
February 07, 2019, 09:32:19 am »
Quote from: mikko k on February 07, 2019, 08:55:21 am
thank you!
just need to get the guides checked because one of them isn't seated completely anymore and I have the feeling that there is a little bit of play between the valve and guides..
Glauco
Re: 043 head info
February 07, 2019, 09:33:47 am »
Quote from: alex d on February 07, 2019, 09:09:32 am
I had the same impression, but have no idea what they were used for..
Didn't cc them yet, going to try to get them measured today..
glauco
alex d
Re: 043 head info
February 07, 2019, 11:16:51 am »
these Autocraft Stage IV look very similar to your heads
Glauco
Re: 043 head info
February 07, 2019, 12:03:10 pm »
Quote from: alex d on February 07, 2019, 11:16:51 am
they look very similar indeed! thanks, I think I can work from there
Pedalpusher
Re: 043 head info
February 08, 2019, 07:34:13 am »
Quote from: Glauco on February 07, 2019, 08:14:15 am
Glauco
Ok thanks for the info! Makes sense now.
I guess it's not really a quick job to change back to normal 'cause reworking the valve seats too..
-Mikko-
