September 26, 2026, 15:10:53 pm
| | |-+  5x130 on oval beetle
Author Topic: 5x130 on oval beetle  (Read 5244 times)
Jesse/DVK
'64 2176cc
« on: April 23, 2019, 21:04:40 pm »
Guys,
I bought a set of OG Gasburners for my '54 oval. In the front I will be running discs with 5x130 and dropped spindles. In the rear I want to keep drums for now but I can't find any 5x130 drums for early cars. Should I run adapters, this might be a good option because I believe you need to run a spacer at the back to clear the spring plates with gasburners.
aki
« Reply #1 on: April 23, 2019, 21:55:06 pm »
I had OG Gasburners in my ex-oval in the past. I had discs in the front and converted rear to late beetle drums. First I had short axles and spacers (5-7mm if I remember correctly) but converted later to long axles. That was definitely better option in this combination. With ’54 you have different hand brake setup so I believe you might need flip the late model backing plates.
« Reply #2 on: April 23, 2019, 22:41:55 pm »
Buy late 4 lug drums drilled for porsche, have a machine shop modify to use them on short axle.
You could then run a spacer if required.
Lee
Erlend / bug66
Global Moderator
SCC Event
« Reply #3 on: April 24, 2019, 10:17:05 am »
5x130 drums: https://www.machine7.com/product.php?xProd=1661&xSec=992
Can be turned down or machined for short axles.
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
