July 22, 2026, 01:44:30 am
352240 Posts in 28934 Topics by 6923 Members
| |-+  Technical stuff
| | |-+  What power should this engine make
Author Topic: What power should this engine make  (Read 5289 times)
John64
« on: April 26, 2019, 10:18:10 am »
I have recently bought a beetle and the engine spec is detailed below. Can anyone estimate what sort of power this should be making. Also where will the powerband be and what would recommend for rev limit.
ENGINE SPEC :- 1914 cc
 AS 41 CASE DRILLED AND TAPPED FOR FULL FLOW.
 69mm BUG PACK 8 DOWLED COUNTER WIEGHT CRANK
 STOCK CON RODS
 LIGHTENED CHROMOLLY FLY WHEEL
 94mm BARREL AND PISTONS
 ENGLE 125 CAM
 CB 30mm LIGHT WIEGHT LIFTERS
 CB STRAIGHT CUT TIMMING GEAR
 GENE BURG COUNTERWIEGHT PULLEY
 BUG PACK CHROMOLLY CUT TO LENGTH PUSH RODS
 JC PUSHROD TUBES
 CB 044 HEADS, SMALL OVAL PORT
 42 X 37 1/2mm STAINLESS VALVES
 9 1/2 TO 1 COMPRESSION
 SKAT VW STYLE 1.25 TO 1 ROCKERS ON BOLT UP SHAFTS
 SKAT DUAL SPRINGS
 CHROMOLLY RETAINERS
 1 5/8" STAINLESS SPEED SHOP HEADER
 2 1/2" STAINLESS SPEED SHOP MUFFLER
 SKAT TRAK MANIFOLDS
 WEBER 48 IDA'S, RUNNING 37 mm VENTURIS
MSD Coil
MSD Dizzy
MSD 6 AL
 FULL FLOW OIL SYSTEM
 REAR ENGINE BRACE
 16 ROW OIL COOLER
 STAGE ONE KENNEDY PREASURE PLATE
 DAIKEN DISK
 RANCHO PRO STREET GEARBOX
 INTERMEDIATE GEARBOX MOUNT
 SHORT AXLES
Drilled front Discs dual circuit brakes
Koni Shocks
MSD Launch Control
Line Lock
John
« Last Edit: April 26, 2019, 10:23:04 am by John64 » Logged
T11964
« Reply #1 on: April 26, 2019, 13:24:59 pm »
Built a 1914 for a friend , with the parts he had , Engle 120 , ported heads 42/37,5
9,5 comp.  Python 15/8 exhaust  , made 148 hp , not much Down low ( too big ports)
but a lot of fun 👍
« Reply #2 on: April 26, 2019, 18:45:32 pm »
I'm pretty sure Pete Roberts at Funkenblitz built the motor. Give him a call as I'm sure he will know
John64
« Reply #3 on: April 26, 2019, 18:48:08 pm »
Yes it was Pete that built it. Didn’t want to bother him about it though.
« Reply #4 on: April 28, 2019, 03:28:07 am »
If you can find someone with a chassis dyno that’s the best.
I had mine done at a car show and it was cheap!
