September 26, 2026, 17:25:23 pm
Technical stuff
What power should this engine make
Topic: What power should this engine make (Read 5999 times)
John64
April 26, 2019, 10:18:10 am »
I have recently bought a beetle and the engine spec is detailed below. Can anyone estimate what sort of power this should be making. Also where will the powerband be and what would recommend for rev limit.
ENGINE SPEC :- 1914 cc
AS 41 CASE DRILLED AND TAPPED FOR FULL FLOW.
69mm BUG PACK 8 DOWLED COUNTER WIEGHT CRANK
STOCK CON RODS
LIGHTENED CHROMOLLY FLY WHEEL
94mm BARREL AND PISTONS
ENGLE 125 CAM
CB 30mm LIGHT WIEGHT LIFTERS
CB STRAIGHT CUT TIMMING GEAR
GENE BURG COUNTERWIEGHT PULLEY
BUG PACK CHROMOLLY CUT TO LENGTH PUSH RODS
JC PUSHROD TUBES
CB 044 HEADS, SMALL OVAL PORT
42 X 37 1/2mm STAINLESS VALVES
9 1/2 TO 1 COMPRESSION
SKAT VW STYLE 1.25 TO 1 ROCKERS ON BOLT UP SHAFTS
SKAT DUAL SPRINGS
CHROMOLLY RETAINERS
1 5/8" STAINLESS SPEED SHOP HEADER
2 1/2" STAINLESS SPEED SHOP MUFFLER
SKAT TRAK MANIFOLDS
WEBER 48 IDA'S, RUNNING 37 mm VENTURIS
MSD Coil
MSD Dizzy
MSD 6 AL
FULL FLOW OIL SYSTEM
REAR ENGINE BRACE
16 ROW OIL COOLER
STAGE ONE KENNEDY PREASURE PLATE
DAIKEN DISK
RANCHO PRO STREET GEARBOX
INTERMEDIATE GEARBOX MOUNT
SHORT AXLES
Drilled front Discs dual circuit brakes
Koni Shocks
MSD Launch Control
Line Lock
John
Last Edit: April 26, 2019, 10:23:04 am by John64
T11964
Re: What power should this engine make
April 26, 2019, 13:24:59 pm »
Built a 1914 for a friend , with the parts he had , Engle 120 , ported heads 42/37,5
9,5 comp. Python 15/8 exhaust , made 148 hp , not much Down low ( too big ports)
but a lot of fun 👍
April 26, 2019, 18:45:32 pm »
I'm pretty sure Pete Roberts at Funkenblitz built the motor. Give him a call as I'm sure he will know
John64
April 26, 2019, 18:48:08 pm »
Quote from: leec on April 26, 2019, 18:45:32 pm
Yes it was Pete that built it. Didn’t want to bother him about it though.
April 28, 2019, 03:28:07 am »
If you can find someone with a chassis dyno that’s the best.
I had mine done at a car show and it was cheap!
